#1 2022-03-08 21:16:53
mongoosander
Keyboard layout change doesn't take effect (Devuan 4 Chimaera)
Changing the layout settings in Settings>Keyboard>Layout (after installing my language, EN UK), the change does not take effect.
#2 2022-03-08 22:02:43
Re: Keyboard layout change doesn't take effect (Devuan 4 Chimaera)
Try
# apt install keyboard-configuration console-setup
# dpkg-reconfigure keyboard-configuration
# service keyboard-setup restart
Reference: https://wiki.debian.org/Keyboard
#3 2022-03-12 19:26:50
mongoosander
Thanks. When I run:
I get:
keyboard-setup: unrecognized service
I've set the keyboard to my locale (UK) but the @ and " keys are still in the wrong place.
#4 2022-03-13 09:51:10
See 'man loadkeys' - I think it's loadkeys UK, but might be GB.
#5 2022-03-14 12:28:28
Ermiq
You didn't tell what DE you use, so assuming that you use XFCE as the Devuan's default DE, I think it's probably XFCE specific issue. Just tested it in MATE DE by adding UK layout and it works fine.
XFCE has a config file for keyboard layouts in ~/.config/xfce4/xfconf/xfce-perchannel-xml/keyboard-layout.xml. Check out the contents of this file. I think it should have uk in the layout property field, something like this <property name="XkbLayout" type="string" value="uk"/>. Or <property name="XkbLayout" type="string" value="uk,us"/> if you have both UK and US layouts.
