I am thinking about trying to use Zoom and Google Meet on a remote computer, for example inside a Linode guest with Tiger VNC + JWM.
I need to pass sound in both directions somehow. Open source VNC by its own AFAIK does not support remote sound.
I would not like to use Pulse Audio because I do not like anything from this systemD programmer ![]()
Also I would prefer to avoid popular sound servers like NAS.
What do you think about trying to use ffmpeg and ALSA loopback for the task?
So I could make two streams:
1) From my workstation to Linode VPS:
VideoCam + Microphone -> local ffmpeg streaming -> UDP -> remote ffmpeg -> loopback devices (ALSA and V4L) -> Zoom / Google Meet
https://trac.ffmpeg.org/wiki/StreamingGuide
https://trac.ffmpeg.org/wiki/Capture/ALSA
2) From Linode VPS to my workstation:
Zoom / Google Meet on Linode VPS -> ALSA loopback -> remote ffmpeg streaming -> UDP -> some player capable to open a sound stream
Also I will look at VNC to see another party.
There is even a place for improvement. I can try to capture program window like Zoom or Chromium directly to ffmpeg too and pass remote video from another party via multimedia stream too and see it in a player instead of VNC client.
Regarding to codec, I guess Opus can be used:
https://www.reddit.com/r/ffmpeg/comment … pus_codec/
http://www.pogo.org.uk/~mark/trx/stream … audio.html
My goal is to improve video session stability by executing video chat client on the modern Linode host with a fast internet in their datacenter.
So if my connection brokes or sometimes becomes slow I would not drop from the video session completely but rather only will miss some UDP packets from ffmpeg which is acceptable for me.
Also I am going to protect my Internet line between my home and Linode by some type of a VPN, may be UDP Wireguard.
