Pages: 1
I have xfce as my main desktop and i wanted to try xmonad.
sudo apt-get install xmonad
I log out and in the login screen with F1 i choose as session xmonad.
But when i log in i see the same devuan default background with the text (xmonad session)
but nothing happens.
It's supposed to be able to launch a terminal with Alt + Shift + Enter.
System:
Host: enoush2o Kernel: 5.15.0-3-amd64 x86_64 bits: 64 Desktop: Xfce 4.16.0
Distro: Devuan GNU/Linux 5 (daedalus/ceres)
Have you tried <Mod4>+<shift>+<return>? Mod4 is also known as the "Windows" key.
And is a terminal emulator installed?
update-alternatives --display x-terminal-emulatorOtherwise check ~/.xsession-errors for any clues.
It seems there is an x-terminal-emulator.
As for the 'windows' key i'll need more time to search because my keyboard is a ergodox with custom mapping with no such key.
$ update-alternatives --display x-terminal-emulator
x-terminal-emulator - auto mode
link best version is /usr/bin/xfce4-terminal.wrapper
link currently points to /usr/bin/xfce4-terminal.wrapper
link x-terminal-emulator is /usr/bin/x-terminal-emulator
slave x-terminal-emulator.1.gz is /usr/share/man/man1/x-terminal-emulator.1.gz
/usr/bin/koi8rxterm - priority 20
slave x-terminal-emulator.1.gz: /usr/share/man/man1/koi8rxterm.1.gz
/usr/bin/lxterm - priority 30
slave x-terminal-emulator.1.gz: /usr/share/man/man1/lxterm.1.gz
/usr/bin/uxterm - priority 20
slave x-terminal-emulator.1.gz: /usr/share/man/man1/uxterm.1.gz
/usr/bin/xfce4-terminal.wrapper - priority 40
slave x-terminal-emulator.1.gz: /usr/share/man/man1/xfce4-terminal.1.gz
/usr/bin/xterm - priority 20
slave x-terminal-emulator.1.gz: /usr/share/man/man1/xterm.1.gz
Nice :-)
Anyway it looks like mod1 (<alt>) is actually the default in Debian's xmonad package so check ~/.xsession-errors after trying to launch xfce4-terminal a few times.
Pages: 1
