Hello everybody!
Every time the display goes off 'intel_reg write' gets disabled.
Every time have to restart it manually. It' very annoying.
intel_reg write 0x61254 0x07a10232
Warning: register spec not found in '/usr/share/igt-gpu-tools/registers'. Using builtin register spec.How to make it permanent?
See https://github.com/edio/intelpwm-udev for a script, configuration file and udev rule to set the PWM frequency automatically.
udevadm info --path=/sys/usr/lib/udev/rules.d/99-intelpwm.rules --attribute-walk
syspath not foundudevadm test /usr/lib/udev/rules.d/99-intelpwm.rules
GOTO 'backlight_pwm_rules_end' has no matching label in: '/usr/lib/udev/rules.d/99-intelpwm.rules'
unable to open device '/sys/usr/lib/udev/rules.d/99-intelpwm.rules'
Unload module indexfor the record
cat /usr/lib/udev/rules.d/99-intelpwm.rules
KERNEL!="intel_backlight", SUBSYSTEM!="backlight", ACTION!="change", GOTO="backlight_pwm_rules_end"
RUN="/usr/lib/udev/intelpwm"
LABEL="backlight_pwm_rules_end"Last edited by amaro (2022-02-13 14:22:20)
Why have you placed the intelpwm script under /usr/lib/udev/? I think /usr/local/bin would be better. Is the intelpwm script executable? It might be best to open an issue in the linked GitHub repository if that doesn't make it work because I don't use Intel and so have no way of testing this.
It's not important but local udev rules belong in /etc/udev/rules.d/, /usr/lib/udev/rules.d/ is for rules supplied by packages.
The udevadm info command makes no sense at all, what are you trying to achieve with that?
Anyway if you can't get the udev rule working you can try this file at /etc/modprode.d/i915-pwm.conf instead:
install i915 /usr/local/bin/intelpwm ; /sbin/modprobe i915 --ignore-installMake sure the intelpwm script is executable.
@Head_on_a_Stick
1. followed the instructions in the 'readme' file but it seems they are not adequate
2. 'udev info' and 'udev test' commands got from ubuntu forum when looking for solutions
3. after a reboot got the message
GOTO 'backlight_pwm_rules_end' has no matching label in: '/usr/lib/udev/rules.d/99-intelpwm.rules'once into the login window my keyboard did not work
anyway, thank you for the suggestions!
So does the /etc/modprobe.d/i915-pwm.conf suggestion work?
I dont have 'ansible' and cannot install it due to the lack of space.
Besides I am not sure this script works correctly here.
output after display was off i.e. with default frequency
intel_reg dump | grep PWM
                        BLC_PWM_CTL (0x00061254): 0x02320232
                       BLC_PWM_CTL2 (0x00061250): 0xf3ffffffoutput after running the script manually
'/usr/lib/udev/intelpwm'
root@6910p:~# /usr/lib/udev/intelpwm
Writing 0x71bbeffff to register 0x61250
root@6910p:~# intel_reg dump | grep PWM
                       BLC_PWM_CTL2 (0x00061250): 0xf3ffffffoutput after manually set the frequency
'fm' is alias for 'intel_reg write 0x61250 0x07a10232'
root@6910p:~# fm
                       BLC_PWM_CTL2 (0x00061250): 0x03a10232Offline
What is the content of /etc/intelpwm.conf?
As I said earlier it might be best to open an issue on the GitHub repository so the author of the script can advise.
I removed all files and then went through the installation process again.
Just to make sure everything is done correctly.
The one difference is this time I copy/pasted the 'udev rule' in both places.
It seems to work now.
Thank you for being persisitent with your suggestions, Head_on_a_Stick!
