#1 2022-02-04 18:12:38
jpark
[SOLVED] USB Device (keyboard) problem
I keep getting this message repeating again and again.. in dmesg -wH
Should I use a different keyboard?
[Feb 4 09:55] usb 5-1-port2: disabled by hub (EMI?), re-enabling...
[  +0.000007] usb 5-1.2: USB disconnect, device number 11
[  +0.911151] usb 5-1.2: new full-speed USB device number 12 using xhci_hcd
[  +0.224837] usb 5-1.2: New USB device found, idVendor=258a, idProduct=1006, bcdDevice=20.03
[  +0.000002] usb 5-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  +0.000001] usb 5-1.2: Product: Gaming KB
[  +0.000001] usb 5-1.2: Manufacturer: Gaming KB
[  +0.085267] input: Gaming KB  Gaming KB  as /devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb5/5-1/5-1.2/5-1.2:1.0/0003:258A:1006.0010/input/input42
[  +0.057789] hid-generic 0003:258A:1006.0010: input,hidraw4: USB HID v1.11 Keyboard [Gaming KB  Gaming KB ] on usb-0000:0f:00.3-1.2/input0
[  +0.004252] input: Gaming KB  Gaming KB  System Control as /devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb5/5-1/5-1.2/5-1.2:1.1/0003:258A:1006.0011/input/input43
[  +0.063731] input: Gaming KB  Gaming KB  Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb5/5-1/5-1.2/5-1.2:1.1/0003:258A:1006.0011/input/input44
[  +0.000053] input: Gaming KB  Gaming KB  Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0f:00.3/usb5/5-1/5-1.2/5-1.2:1.1/0003:258A:1006.0011/input/input45
[  +0.000075] hid-generic 0003:258A:1006.0011: input,hiddev2,hidraw5: USB HID v1.11 Keyboard [Gaming KB  Gaming KB ] on usb-0000:0f:00.3-1.2/input1
#2 2022-02-04 18:15:23
Re: [SOLVED] USB Device (keyboard) problem
Do you actually have any problems with the keyboard apart from the dmesg spam?
Could be a dodgy cable and/or connector.
#3 2022-02-04 18:18:47
jpark
Seems to work ok,  I guess its just spam then?
Tried wiggling the cable, disconnect and reconnect.. I'll see if that helps anything.
#4 2022-02-08 19:31:28
jpark
I've found another issue that might be related..  once in awhile the keyboard goes dead.
So I tried switching usb ports , doesn't help.
I found this script which seems to reset the usb , and it does end up working again.. :
#!/bin/bash
if [[ $EUID != 0 ]] ; then
  echo This must be run as root!
  exit 1
fi
for xhci in /sys/bus/pci/drivers/?hci_hcd ; do
  if ! cd $xhci ; then
    echo Weird error. Failed to change directory to $xhci
    exit 1
  fi
  echo Resetting devices from $xhci...
  for i in ????:??:??.? ; do
    echo -n "$i" > unbind
    echo -n "$i" > bind
  done
done
