#1 2022-02-01 23:53:52
tempvuan1
Help - list all services
Hello,
What is the preferred method for listing all installed services in Devuan (Chimaera)?
From debian and derivatives, i was used to command:
service --status-all
Regards,
#2 2022-02-02 02:26:15
ruenoak
Re: Help - list all services
Hi tempvan1,
I think you need to use the whole path
/usr/sbin/service --status-all
Thanks
R
"Has cat, eats cheese, drinks coffee, Chaotic Neutral " smile
#3 2022-02-02 09:36:29
To su to root, type "su -"
I think that may be your solution. It's in the release notes.
#4 2022-02-02 09:46:03
alexkemp
ruenoak wrote:
Hi tempvan1,
That certainly works. However, for me so does the bare service --status-all (as an ordinary user, under chimaera, tested just now).
#5 2022-02-02 15:10:36
The OP can view all installed services (ie, even those not running) by checking /etc/init.d/.
#6 2022-09-19 22:37:19
kaiyel
If you've migrated from the Redhat world where you were comfortable with "chkconfig --list",
apt-get install -y sysv-rc-conf
and see if you like "sysv-rc-conf --list".
--K
#7 2022-09-20 05:15:46
I have open-rc and so we can use,
rc-update
to view status.
you can add, del or change a service and start level.
rc-update del nethack-common default
rc-update add nethack-common off
I have seen that the old service commands mostly still work, I don't use many of them, and only know a few.
status gives +-? results
type "service" to see the command options.
Hope this helps.
