#1 2022-01-28 22:00:49
nielsblack
cmst (Connman System Tray) unresponsive with wifi
I've recently installed Devuan on an old eeePC 701, and I chose to only install the LXQT desktop (which installed Connman and cmst). I used Ethernet during install, and afterwards I unplugged it and tried to get wifi working. Cmst said wifi was off, and the keyboard switch wouldn't turn it on. I was able to turn it on with connman in the terminal, but now cmst is unusable! It chews up 100% CPU and is almost completely unresponsive. I've tried purging and reinstalling it, and I've tried launching it from the terminal, hoping it would throw some errors, but no luck and I'm not sure how to troubleshoot it further. For now I'm able to connect to wifi with connman through the terminal, but I'd like to help figure this out.
