#1 2022-01-18 16:46:08
MLEvD
How to disable nm-applet and cinnamon screensaver?
Using minty base for devuan, installed devuan cinnamon to avoid a lot of mint dependancies, shocked to find that devuan cinnamon demands network-manager!
Asking for a friend with little ram.
#2 2022-01-18 18:01:12
Re: How to disable nm-applet and cinnamon screensaver?
Cinnamon seems a bizarre choice for a low RAM desktop but anyway...
Stop the network-manager service and prevent it from starting at boot:
sudo /etc/init.d/network-manager stop
sudo update-rc.d network-manager disable
Copy the various .desktop files for the screensaver & nm-applet to "$HOME":
cp /etc/xdg/autostart/{cinnamon-settings-daemon-screensaver-proxy,nm-applet}.desktop /usr/share/applications/cinnamon-screensaver.desktop ~/.config/autostart
Disable autostart by adding 'Hidden=true' to the end of all .desktop files in "$HOME" (do this manually if you already have autostart files there that you don't want to disable):
for i in ~/.config/autostart/*.desktop ; do echo 'Hidden=true' >> "$i" ; done
Then log out & back in again.
#3 2022-01-19 10:07:31
xinomilo
Unknown
btw, i don't think running cinnamon-core "demands" network-manager.. some metapackage could, but you can run any DE without metapackages and keep it simpler / to your needs.
so, you can probably use another network manager (connman?) and purge anything network-manager related..
#4 2022-01-19 15:39:18
The cinnamon-core metapackge does pull in network-manager even if --no-install-recommends is passed, which is annoying.
EDIT: actually this works:
# apt install network-manager- connman
I presume cinnamon-core has a networking virtual package dependency which is also satisfied by connman. Still stupid though because ifupdown can handle networking just fine without needing any extra packages.
