#1 2022-01-04 16:37:17
kaiyel
[SOLVED] Missing RapidSVN
Since upgrading to chimaera, RapidSVN is no longer available :
$ apt-get download rapidsvn
E: Can't find a source to download version '0.12.1dfsg-3.1+b1' of 'rapidsvn:amd64'
$ apt-get source rapidsvn
E: Can not find version '0.12.1dfsg-3.1' of package 'rapidsvn'
E: Unable to find a source package for rapidsvn
Did it not make the cut / does a better (one that does not involve Java or KDE libs) alternative exist?
Thanks,
--K
#2 2022-01-04 17:43:31
xinomilo
Unknown
Re: [SOLVED] Missing RapidSVN
rapidsvn has been removed from Debian (& Devuan) : https://bugs.debian.org/cgi-bin/bugrepo … bug=941178
you could stick with beowulf if you want to still use that..
as for other svn gui's maybe try searching around for alternatives. i can only see anjuta by searching with apt, but never really used a gui with svn...
edit] https://en.wikipedia.org/wiki/Compariso … on_clients
#3 2022-01-04 22:20:43
kaiyel
Thank you, xinomilo!
--K
