#1 2022-01-03 01:29:02
xorg-server 21.1.3 - Regression fixes
This came into my mailbox a while ago:
This release fixes several regressions since 1.20.x and 21.1.1.
Adam Jackson (1):
       glx/dri: Filter out fbconfigs that don't have a supported pixmap format
Jocelyn Falempe (2):
       xf86/logind: Fix compilation error when built without logind/platform bus
       xf86/logind: fix missing call to vtenter if the platform device is not paused
Matthieu Herrb (1):
       Convert more funcs to use InternalEvent.
Povilas Kanapickas (1):
       xserver 21.1.3
nerdopolis (1):
       os: Try to discover the current seat with the XDG_SEAT var first
xorg-server-21.1.3.tar.gz
https://xorg.freedesktop.org/archive/in … 1.3.tar.gz
PGP:  https://xorg.freedesktop.org/archive/in … tar.gz.sig
Thanks to Povilas Kanapickas it's moving along nicely ...  8^D
