#1 2021-12-25 18:45:13
turbo
[SOLVED] NumLock on at boot time, possible?
Hello All,
is there a way to get NumLock activated before Login?
So it is ready to use for Login Credentials?
#2 2021-12-25 18:56:42
alphalpha
Re: [SOLVED] NumLock on at boot time, possible?
Check your bios options, sometimes there is an option to set numlock at boot.
#3 2021-12-25 19:06:42
Try adding this to /etc/rc.local (needs the kbd package):
initty="/dev/tty[1-6]"
for tty in $initty; do
   /usr/bin/setleds -D +num < "$tty"
done
EDIT: that's for console (TTY) screens.
If you mean for a display manager login see https://wiki.archlinux.org/title/LightD … by_default (for LightDM, other display managers will have similar options for startup scripts and commands).
#4 2021-12-25 22:30:03
turbo
Thank you for the link.
Installed numlockx and works like a charme.
#5 2022-05-01 05:34:07
SpongeBOB
done
It work like a charm ! Thanks HOAS.
