#1 2021-12-20 05:08:04
torquebar
execute a script on log-in
In Artix, Slackware and Suse I can as a user include a line
like:
makeafile.bsh
in the file ~.profile and make that script executable in
directory ~/bashers and then link to it in ~/bashers-linked
To get that path permanently into $PATH I do
export PATH=$PATH:$HOME/bashers-linked
or I can give the full path to the link in ~.profile
~/bashers-linked/makeafile.bsh
This achieves the desired result ...EXCEPT in Devuan.
The script executes if commanded, it's just that I can't
get it to auto-execute on login :-(
Is ~.profile read at all?
What else should I investigate?
TIA
Who, has loved us more?
#2 2021-12-20 05:50:41
Re: execute a script on log-in
#3 2021-12-20 20:44:02
torquebar
Thanks, interesting reads. I was certain that no distro logged
a user in without executing ~/.profile   ...wrong again!
I even tried it in ~/.bashrc that didn't work either, fortunately
it's not a vital issue, in the interim until solution-day I can just
rig a button in the panel to do the same thing on a click.
#4 2021-12-20 21:00:13
Here's a solution (run as your normal user):
tee ~/.xessionrc <<!
export PATH="$PATH":"$HOME"/bashers-linked
[ -f ~/.profile ] && . ~/.profile
Then log out & back in again.
EDIT: that creates a file at ~/.xsessionrc with the content listed between the exclamation marks. Note to self: stop being such an insufferable smart-ass...
#5 2022-02-04 01:23:58
torquebar
thanks, I'll try that, been busy with other things :-)
#6 2022-02-04 02:12:30
torquebar
...done
Now I can click the script I credit to
0-BitTwisters-siggen.bsh
which creates the sig below
The call is still in .profile  as well
#https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=752129
export PATH=$PATH:$HOME/0/bashers-linked
bash ~/0/bashers-linked/0-BitTwisters-siggen.bsh
How do I get this done auto on log-in?  I'm thinking of a similar
inclusion in .xsession.rc to execute .profile
{but maybe it's better if I don't think too much}
Devuan GNU/Linux 4 (chimaera), Kernel=5.10.0-11-amd64 on x86_64,
DM=Unknown, DE=XFCE, ST=x11,grub2, GPT, BIOS-boot
#7 2022-02-04 18:24:44
Remove the PATH line from ~/.xsessionrc if it's being set in ~/.profile and also remove the bash line from ~/.profile then you can call the script from .xsessionrc, like this:
^ That's all you need if the script is executable, is in a PATH directory and has a #!/bin/bash shebang. No need to call the full path or prepend bash.
Alternatively remove any PATH additions and just call the full path to the script.
