#1 2021-12-19 21:50:22
swarfendor437
[SOLVED] No second monitor in Devuan 4
In Devuan 3.0 and 3.1.1 (installed after hard drive failure with 3.0) had no issues with both monitors attached to Nvidiat GT1030 powered card. But with Devuan 4.0 have no luck. Have installed 'arandr' and 'autorarandr' to no avail.
#2 2022-07-24 12:34:19
swarfendor437
Re: [SOLVED] No second monitor in Devuan 4
Solved the problem as my Devuan 4 was running out of space on root, so downgraded to Devuan 3.1.1 - back to normal!
