Chimaera, Xfce4, theme Menta.
You could try setting a different theme for root in /root/.gtkrc-2.0 & /root/.config/gtk-3.0/settings.ini
/root/.config/gtk-3.0/ is empty.
I tried a gtk.css there:
.titlebar {
background: #ff0000;
color:#000000;
.titlebar:backdrop {
background: #a00000;
color:#808080;
Not working.
With mate there's at least a comment "(as admin)" in the title.
When logging in as root (bad idea, I know) there's a warning displayed within the caja window, but the title bar is not red.
Yes, root's $HOME is supposed to be empty.
Oh, clever, I like it :-)
But unfortunately I forgot that Xfce doesn't read the GTK configuration files. Sorry. Try xfconf-query instead (as root).
Xfce4 obviously reads the gtk.css of ~. I change some panel and desktop colors by that.
Maybe it's a syntax error. I wrote the same into the ~/.config/gtk-3.0/gtk.css, restarted, but the title bar didn't change. Maybe the syntax is wrong.
Is there any manual of css syntax used by xfce4? Or by gtk3?
Little step forward.
With /root/.config/gtk-3.0/gtk.css
headerbar {
color: #ffffff;
text-shadow: #000000;
headerbar:backdrop {
background: #800000;
color: #404040;
it works for some GUI as gedit, but not for caja. In caja there is also no effect from ~/.config/gtk-3.0/gtk.css .
Got so far as caja and other GUI's title backgrond (for instance for theme Menta) is set by
@define-color theme_selected_bg_color #accd8a;
in /usr/share/themes/Menta/gtk-3.0/gtk-main.css .
Other entries in there then refer to theme_selected_bg_color.
Das Problem ist nicht wie gewünscht lösbar. Der Titel wird vom Fenstermanager verwaltet und der verwendet die Einstellungen des angemeldeten Nutzers.
Allerdings habe ich jetzt noch menubar und toolbar auf knallrot gesetzt und alle für mich relevanten Programme haben irgendwas davon (headerbar, menubar oder toolbar).
Meine /root/.config/gtk-3.0/gtk.css sieht jetzt so aus:
headerbar {
color: #ffffff;
color: #404040;
menubar,toolbar {
Nicht ganz so elegant wie vorgesehen, aber funktioniert.
