Pages: 1
Just upgraded to Chimaera, installed ufw gives me this error:
root@foo:/home/bobo# ufw enable
bash: ufw: command not found
Installed gufw:
root@foo:/home/bobo# gufw
/usr/bin/gufw: line 2: [: =: unary operator expected
ls: cannot access '/usr/lib/python*/site-packages/gufw/gufw.py': No such file or directory
thanks,
Read the release notes and use the correct command to gain a root shell. You have used the wrong command and so PATH is not set correctly.
Read the "release notes", waste of time, had done that originally, then I remember in
Slackware in order to become root you have to su - to become root. That did it!
bobo@foo:~$ su -
Password:
root@foo:~# ufw enable
Firewall is active and enabled on system startup
root@foo:~#
Thanks Head_on_a_Stick!
su
The behaviour of su changed in Devuan 3 Beowulf. These changes persist
in Devuan 4 Chimaera. Use su - to get root's path or use the full path
to commands if you use only su. See the following for more information:
[17]https://www.debian.org/releases/buster/ … s/ch-infor
mation.en.html#su-environment-variables -
[18]https://wiki.debian.org/NewInBuster -
[19]https://bugs.debian.org/905564
Sorry pal, never saw that section (su)... my bad!
Pages: 1
