#1 2021-10-30 16:57:26
NicePics13
USB gamepad and boy it's a weird one!
Need help with this gamepad:
https://retro-bit.com/sega-collaboration#GenMDusb
When plugging it in a running machine the gamepad defaults to D-input (just press START+B for 5 seconds for X-input). This actually does a usb modeswitch:
ID 0079:0011 DragonRise Inc. Gamepad
ID 045e:028e Microsoft Corp. Xbox360 Controller
Both modes work, but emulating an Xbox360 controller gives you more options and better compatibility.
But.. when rebooting my PC the gamepad reverts to:
ID 0f0d:00c1 Hori Co., Ltd Pro Controller
Completely useless as most games don't recognize it and I have to unplug and reconnect mad
#2 2021-10-31 08:10:28
Re: USB gamepad and boy it's a weird one!
Let's see what udev is doing with the device — open a terminal and run this command (as root):
udevadm monitor
Then plug in the controller and post any and all new output that appears in the terminal afterwards. Probably best to fullscreen the terminal, it might be a lot of information.
antifa ftw!
#3 2021-10-31 09:05:34
NicePics13
When hotplugging:
KERNEL[1698.923150] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
KERNEL[1698.925900] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
KERNEL[1698.934936] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
KERNEL[1698.935526] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22 (input)
KERNEL[1698.935697] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/event16 (input)
KERNEL[1698.935791] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/js0 (input)
KERNEL[1698.935847] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/hidraw/hidraw3 (hidraw)
KERNEL[1698.935905] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
KERNEL[1698.935969] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
KERNEL[1698.936037] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
UDEV  [1698.943260] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
UDEV  [1698.949203] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
UDEV  [1698.949225] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
UDEV  [1698.949493] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22 (input)
UDEV  [1698.951384] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/hidraw/hidraw3 (hidraw)
UDEV  [1698.960610] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/js0 (input)
UDEV  [1699.160257] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/event16 (input)
UDEV  [1699.163646] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
UDEV  [1699.165172] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
UDEV  [1699.169281] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
When switching input mode:
KERNEL[1717.090956] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/event16 (input)
UDEV  [1717.093388] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/event16 (input)
KERNEL[1717.106120] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/js0 (input)
UDEV  [1717.107361] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22/js0 (input)
KERNEL[1717.126255] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22 (input)
KERNEL[1717.126319] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/hidraw/hidraw3 (hidraw)
KERNEL[1717.126370] unbind   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
KERNEL[1717.126404] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
KERNEL[1717.126435] unbind   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
KERNEL[1717.126465] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
KERNEL[1717.126747] unbind   /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
KERNEL[1717.126813] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
UDEV  [1717.127481] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/input/input22 (input)
UDEV  [1717.128495] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006/hidraw/hidraw3 (hidraw)
UDEV  [1717.130157] unbind   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
UDEV  [1717.130841] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/0003:0079:0011.0006 (hid)
UDEV  [1717.132131] unbind   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
UDEV  [1717.132690] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
UDEV  [1717.134186] unbind   /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
UDEV  [1717.134811] remove   /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
KERNEL[1718.206931] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
KERNEL[1718.209735] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
KERNEL[1718.209795] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/leds/xpad0 (leds)
KERNEL[1718.209936] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input23 (input)
KERNEL[1718.210135] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input23/event16 (input)
KERNEL[1718.210201] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input23/js0 (input)
KERNEL[1718.210248] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
KERNEL[1718.210356] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
UDEV  [1718.218070] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
UDEV  [1718.221180] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/leds/xpad0 (leds)
UDEV  [1718.223959] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
UDEV  [1718.223999] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input23 (input)
UDEV  [1718.232928] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input23/js0 (input)
UDEV  [1718.320163] add      /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0/input/input23/event16 (input)
UDEV  [1718.322585] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1/3-1:1.0 (usb)
UDEV  [1718.326544] bind     /devices/pci0000:00/0000:00:02.0/usb3/3-1 (usb)
#4 2021-10-31 09:25:21
NicePics13
big_smile Temp solved the rebooting issue by using one of these to quickly powercycle the gamepad!
