#1 2021-10-23 13:49:32
MLEvD
Chimaera still has bug in audio settings persistance for mate desktop
Hi, to reproduce the bug, launch 'Sound Preferences', select the 'Hardware' tab. Change the 'profile' from 'Analogue stereo duplex' to 'Analogue stereo output'. Close sound preferences and reboot.
When you return, you find your selection has not been saved.
Similarly, on the 'output' tab, the 'Connector' defaults to 'speakers'. Changing it to 'headphones', reboot, it has returned to 'speakers', even when speakers are turned off in bios.
Can somebody tell me please, which devuan specific package is responsible for saving these data? I can't log the bug against mate-media because the version is the same as debian and this bug does not occur in debian.
#2 2021-10-24 20:51:33
mexsudo
Re: Chimaera still has bug in audio settings persistance for mate desktop
I was able to reproduce this bug.
using same machine booting with Debian Mate the hardware edits as described by MLEvD are retained as expected
#3 2021-10-25 10:11:25
MLEvD
After a little detective work and guesswork, looking at devuan specific files that are dependencies of mate-settings-daemon, I would suggest maybe either dbus or libdbus-1-3 are the problem. But how to know for sure, and which?
#4 2021-12-19 15:49:44
MLEvD
New info, a new approach to trying to reproduce bug from a debian base:
Debian Bullseye netinstall, skipping 'install software' stage, chroot /target and apt install sysvinit-core elogind
Boot system and point sources to Devuan Chimaera, upgraded to devuan, rebooted.
Then installed xorg, mate desktop, pulseaudio.
The bug was not reproducible.
It seems the bug doesn't happen when starting from debian, no matter how early you change over to devuan.
#5 2021-12-23 19:07:11
MLEvD
I can confirm the bug is still present in daedalus.
Checked using the latest netinstall iso, noticed there were some alsa related messages flashing past on boot, perhaps a clue?
