#1 2021-10-22 18:25:24
xnpu
[SOLVED] sysvinit, runit, or OpenRC?
Devuan lets us choose between sysvinit, runit, and OpenRC. Having read a little about the differences, they seem to all meet my needs.
So what I would really like to know is: what's everyone else choosing? Which one is most likely to still be supported when Devuan 20 comes around? What did you choose and why?
#2 2021-10-22 19:10:15
Re: [SOLVED] sysvinit, runit, or OpenRC?
I am using openrc since ASCII. Works fine.
My first encounter with runit in a virtual machine a while ago was frustrating. Didn't realy work. Though there are people that are using it with success now. Maybe its time for another try.
#3 2021-10-22 21:22:18
Dutch_Master
Open RC here. Got acquainted with it on Funtoo (Gentoo based). On Ascii it was just a sym-link to SysVinit, but Beowulf has proper implementation. (AFAIK!) Never tried runit.
#4 2021-10-22 23:21:28
devadmin
Sysvinit.
tried to replace it by runit and got some problems with TDE. So have to switch it back.
#5 2021-10-23 04:50:13
kiwi
Had OpenRC back in February.  Came back to Devuan and installed with runit looking for simplicity.
#6 2021-10-23 18:33:26
xnpu
Thanks for the replies. Looks like I'll be using OpenRC!
