#1 2021-10-17 21:00:10
oui
(devuan star 64) how to change the grey range from top bar of windows
the theme of star is very very dark
the top bar of the file manager is middle grey: you can see it very good also if more than one applications windows are at the same place!
the top bar of the browser is dark grey: it is very difficult to recognize it and  I make often errors shutting the wrong application down...
how to amend that?
