#1 2021-10-02 16:50:47
xavannavax
Can I add OpenRC after installing with SysV
I just installed Devuan for the first time and chose SysV for the init system during setup. Is it possible to add OpenRC on top now?
#2 2021-10-02 16:57:14
Dutch_Master
Re: Can I add OpenRC after installing with SysV
Yes you can. However, OpenRC will actually replace SysV on Beowulf. In Ascii, OpenRC was indeed a layer on top of SysV, not so in Beowulf.
