#1 2021-09-29 17:47:28
nonsd
[SOLVED] Compile own kernel
Hello!
Last time I compiled my own kernel was a long (very long) time ago, kernel 2.6.x (only MBR + lilo)
Since then, in every distro I always kept the default kernel that was shipped. Now, with Chimaera (UEFI + GPT + GRUB), the default one is kernel 5.10.
I know that out there are a lot of tutorials with basic steps. But they seem to be a bit incomplete (sorry, I don't know how to be more clear on this.... )
What I would like to do is:
1) Keep kernel 5.10 as a safeguard (in case of any kernel panic when compiling any new/custom kernel)
2) Compile a new kernel using the config-5.10.0-8-amd64 (file located at /boot) as starting point
3) New kernel does not need to be packaged as .deb
- Do I need to compile a new kernel? No, 5.10 is working fine
- Why do I want to compile a new kernel? Well, why not?!?!
I will appreciate any help
#2 2021-09-30 12:16:41
Re: [SOLVED] Compile own kernel
The installed kernels should always be available as boot options if GRUB was installed from the Devuan system.
You may might have to make a new boot entry for your custom kernel though. Not sure if grub-mkconfig will pick it up automatically.
From the custom kernel source tree:
cp /boot/config-$(uname -r) .config
make oldconfig
See also https://wiki.gentoo.org/wiki/Kernel/Con … figuration
Well yeah, nobody needs chocolate but it's really nice...
https://kernel-team.pages.debian.net/kernel-handbook/
EDIT: corrected command block.
antifa ftw!
#3 2021-10-02 12:16:33
nonsd
Hi Head_on_a_Stick
I took a look at your suggestions and I installed kernel 5.14.9, with the creation of .deb packages
First, upgraded the system
apt-get update && apt-get upgrade
Then installed some things
apt-get install -y build-essential libncurses5-dev libelf-dev libssl-dev dwarves
gcc I installed way before this
Now, copy of .config from /boot/config-5.10.0-8-amd64 and
make oldconfig
make menuconfig
I got some erros while compiling, and after searching a bit, I had to edit .config to change one line
CONFIG_SYSTEM_TRUSTED_KEYS=""
Finally,
make deb-pkg -j4
and, to install those .deb
dpkg -i linux-*.deb
This:
grub-mkconfig
was not needed.
Reboot and everything seems to be working fine.
Btw, compilation took 2h30m to finish on this core i3 3rd-gen, with 8gb ram and regular hdd.
Thanks!!
