#1 2021-09-19 21:41:42
oui
other distros: ExTiX (actually at distrowatch in the left marge!)
I did try it. ISO written directly with DD on a USB stick.
starts perfectly after moving into the RAM and fast, fast, it is best...
a probably complete Deepin scope of applications
I did not find more documentation or user reports.
the first question each one will probably have: can I add applications and remaster somewhat and re use them next start?
as real Devuan fan (as I am) the second question would probably be:
can I do the same with conventional app's from Debian through the repositories from Devuan?
