#1 2021-06-06 10:34:55
swarfendor437
Printing issues - can't print more than 1 copy from an application
Hi everyone,
Had to replace a failing hard drive this week and decided to download the latest version, 3.1.1 DVD iso. Installed the same way as previously, choosing separate /var and /home. Printer picked up correctly as Canon TS8000 series (TS8151). Haven't installed the PPD from Canon. If I unlock the printer, the number of copies is set as 1 which is what I would want as default but if I need to make more than one copy, even choosing from the Application being used to print from it does not change - any ideas?
Thanks for reading.
