#1 2021-06-01 21:31:07
macondo
[SOLVED] Beowulf
Just installed Beowulf, tried to install xfburn and brasero, i get this error:
"Reading state information... Error!
E: Unable to parse package file /var/lib/apt/extended_states (1)"
any ideas??
#2 2021-06-01 23:07:48
andyprough
Re: [SOLVED] Beowulf
apt has run into an error with cache handling, the solution is to delete '/var/lib/apt/extended_states (1)' and run apt update again.
Here's a bug report for your reference: https://bugs.debian.org/cgi-bin/bugrepo … bug=814443
Making a backup copy of the file before deleting it is recommended if you are trying to submit a bug report or debug the issue.
