Hello,
Following Ansible code does NOT start docker service under Devuan Beowulf:
- name: Ensure docker deamon is running
service:
state: startedcat /var/log/docker.log:
Failed to start containerd: exec: "docker-containerd": executable file not found in $PATHThough following code works fine:
- name: Start docker service
command: service docker start
args:
warn: FalseLets try SSH:
ssh host "service docker start"works fine (without a further fix) too.
I was able to fix the problem by customizing docker's rc script by adding:
export PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/binat the top of the file: /etc/init.d/docker
Is it a bug?
