Pages: 1
Has anyone here successfully installed nemo-dropbox on chimeara/ceres?
Any pointers are most appreciated. ![]()
Pax vobiscum,
Mark Rabideau - ManyRoads
dwm, i3wm, openbox on debian test ~ Linux #449130
Have you tried just installing Mint's .deb directly?
http://packages.linuxmint.com/pool/back … o-dropbox/
I haven't tried it myself but apt won't let you install it if there are dependency issues.
I tried installing the deb package from Mint Debbie on Beowulf today, and after the first 3 install failures it looked like I was headed into dependency hell, so I quickly gave up.
^ Were you using dpkg?
# apt install /full/path/to/.deb^ That will install any dependencies automatically, providing they are available from the current sources.
No I don't usually install debs with dpkg on my personal machines, I prefer apt. It wanted to pull in a bunch of cinnamon desktop and other Minty stuff, and I couldn't be bothered any longer. I did not need it to run, I was just curious to see if I could easily install it with the one package. After the third failure and asking for more and more packages I grew bored with the whole endeavor.
I just surrendered and went back to where I was before.... ![]()
Pax vobiscum,
Pages: 1
