#1 2021-04-29 15:08:44
[SOLVED] Piper and ratbag
Finally got around to purchasing a trackball.
Not the one I wanted as it is not manufactured anymore.
But this one seems a reasonable compromise on price/quality. (LT M575)
We'll see if I can get used to using it, works with thumb instead of fingers.
Muscle memory is a mean thing ...
To configure DPI, buttons etc. I downloaded an application called piper which depends on ratbagd >=0.13
But the version in the repository is 0.9.905-1.
groucho@devuan:~$ sudo apt install piper
Building dependency tree
 piper : Depends: ratbagd (>= 0.13)
groucho@devuan:~$
Is there anything I can do about this?
Thanks in advance,
#2 2021-04-29 16:49:51
Re: [SOLVED] Piper and ratbag
From where did you attempt to obtain the piper package?
It is available from beowulf-backports, the version there depends on the ratbagd package also from beowulf-backports and so should be installable.
#3 2021-04-29 19:01:50
... where did you attempt to obtain the piper package?
Piper 0.1-1-bpo+1 (stable-backports)
0.15-1-bpo10+1 (stable-backports)
and
0.9.905-1 (stable)
... but for some reason apt pulls in 0.9.905-1 (stable) when the dependency is the higher version.
Must be doing something wrong. (?)
Thanks for your input.
#4 2021-04-29 19:21:09
Can we see
apt policy
apt policy piper
apt install -s piper/stable-backports
#5 2021-04-29 19:37:06
Can we see ...
groucho@devuan:~$ apt policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 100 http://deb.devuan.org/merged beowulf-backports/main i386 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=main,b=i386
     origin deb.devuan.org
 100 http://deb.devuan.org/merged beowulf-backports/main amd64 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=main,b=amd64
 100 http://deb.devuan.org/merged beowulf-backports/contrib i386 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=contrib,b=i386
 100 http://deb.devuan.org/merged beowulf-backports/contrib amd64 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=contrib,b=amd64
 100 http://deb.devuan.org/merged beowulf-backports/non-free i386 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=non-free,b=i386
 100 http://deb.devuan.org/merged beowulf-backports/non-free amd64 Packages
     release v=3.0.0,o=Devuan Backports,a=stable-backports,n=beowulf-backports,l=Devuan Backports,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf-updates/main i386 Packages
     release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf-updates/main amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-updates,n=beowulf-updates,l=Devuan,c=main,b=amd64
 500 http://deb.devuan.org/merged beowulf-security/non-free i386 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=non-free,b=i386
 500 http://deb.devuan.org/merged beowulf-security/non-free amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf-security/main i386 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf-security/main amd64 Packages
     release v=3.0.0,o=Devuan,a=stable-security,n=beowulf-security,l=Devuan-Security,c=main,b=amd64
 500 http://deb.devuan.org/merged beowulf/non-free i386 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=non-free,b=i386
 500 http://deb.devuan.org/merged beowulf/non-free amd64 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=non-free,b=amd64
 500 http://deb.devuan.org/merged beowulf/contrib i386 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=contrib,b=i386
 500 http://deb.devuan.org/merged beowulf/contrib amd64 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=contrib,b=amd64
 500 http://deb.devuan.org/merged beowulf/main i386 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=main,b=i386
 500 http://deb.devuan.org/merged beowulf/main amd64 Packages
     release v=3.0,o=Devuan,a=stable,n=beowulf,l=Devuan,c=main,b=amd64
Pinned packages:
groucho@devuan:~$
groucho@devuan:~$ apt policy piper
piper:
  Installed: (none)
  Candidate: 0.4-1~bpo10+1
  Version table:
     0.4-1~bpo10+1 100
groucho@devuan:~$
groucho@devuan:~$ apt install -s piper/stable-backports
NOTE: This is only a simulation!
      apt needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
Selected version '0.4-1~bpo10+1' (Devuan Backports:3.0.0/stable-backports [all]) for 'piper'
Selected version '0.15-1~bpo10+1' (Devuan Backports:3.0.0/stable-backports [amd64]) for 'ratbagd' because of 'piper'
  gir1.2-rsvg-2.0 python3-evdev ratbagd
Suggested packages:
  python-evdev-doc
  gir1.2-rsvg-2.0 piper python3-evdev ratbagd
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Inst gir1.2-rsvg-2.0 (2.44.10-2.1 Devuan:3.0/stable [amd64])
Inst python3-evdev (1.1.2+dfsg-1+b10 Devuan:3.0/stable [amd64])
Inst ratbagd (0.15-1~bpo10+1 Devuan Backports:3.0.0/stable-backports [amd64])
Inst piper (0.4-1~bpo10+1 Devuan Backports:3.0.0/stable-backports [all])
Conf gir1.2-rsvg-2.0 (2.44.10-2.1 Devuan:3.0/stable [amd64])
Conf python3-evdev (1.1.2+dfsg-1+b10 Devuan:3.0/stable [amd64])
Conf ratbagd (0.15-1~bpo10+1 Devuan Backports:3.0.0/stable-backports [amd64])
Conf piper (0.4-1~bpo10+1 Devuan Backports:3.0.0/stable-backports [all])
groucho@devuan:~$
#6 2021-04-29 19:41:28
Yeah, you just need to target backports explicitly so that the correct dependency is selected:
# apt install piper/beowulf-backports
FWIW I think aptitude would have probably figured it out for you :-)
#7 2021-04-29 20:15:00
... just need to target backports explicitly so that the correct dependency is selected:
I see ...
I would have though that apt would have done it.
It is quite clear that apt knows that the dependency is ratbagd >=0.13
... aptitude would have probably figured it out for you
I use aptitude for its why and why-not.
And synaptic for its search and residual functions.
But I like apt best.
Thanks a lot for making sense of this for me.
Edit:
Unfortunately, Piper (piper/stable-backports 0.4-1~bpo10+1) does not support the Logitech M575.
It's really up to ratbagd (0.15-1~bpo10+1), as it seems that Piper is the front end.
Notwithstanding, parameters (in Xfce) can be adjusted via Applications -> Settings -> Mouse and Touchpad.
It recognises the device as Logitech ERGO M575 without any user intervention.
