#1 2021-04-23 17:35:56
Modules, modprobe(.d) and kernel command line
Here I am again with another chapter of the e1000e saga.
This particular one regarding module loading how-to.
If interested, here's some background: https://dev1galaxy.org/viewtopic.php?id=4274
From what I have learnt, apart from how the install sets up modules to be loaded, it can be done via modprobe from the command line
eg:
groucho@devuan:~$ sudo modprobe e1000e
Also, module configuration parameters can be added by adding a proper stanza to the kerneo command line:
groucho@devuan:~$ sudo dmesg
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-16-amd64 root=UUID=d6841f29-e39b-4c87-9c52-3a9c3bafe2d3 ro e1000e.EEE=0 .....
groucho@devuan:~$
... or by adding a *.conf file in /etc/modprobe.d:
eg:
groucho@devuan:~$ echo "options e1000e EEE=0" | sudo tee /etc/modprobe.d/e1000e.conf
groucho@devuan:~$ cat /etc/modprobe.d/e1000e.conf
groucho@devuan:~$
I don't know if there's more to this, but that's what I have an idea about.
Now, let's see what's happening with my nemesis, the e1000e module:
If I add the e1000e.EEE=0 stanza to the kernel command line, I get this line in dmesg:
groucho@devuan:~$ sudo dmesg | grep e1000e
[    2.158949] e1000e: unknown parameter 'EEE' ignored
[    2.237022] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.257549] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
groucho@devuan:~$
Curiously enough, calling the wrong module ie: igb.EEE=0 does not generate a message of any sort.
Right.
As the kernel command line trick obviously does not work, I tried using the *.conf above.
As a result, I get this line in dmesg:
[    2.166788] e1000e: unknown parameter 'EEE' ignored
[    2.227702] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.241841] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
groucho@devuan:~$
Clearly the e1000e module exists and is accessed (as far as the kernel is concerned), but does not accept the EEE parameter.
The last option I have is trying with modprobe.
1. see if it is loaded
groucho@devuan:~$ lsmod | grep -i e1000e
e1000e                282624  0
groucho@devuan:~$
2. unload it and check
[root@devuan groucho]# rmmod e1000e
[root@devuan groucho]# lsmod | grep e1000e
3. load it again with the required parameter
[root@devuan groucho]# modprobe -v e1000e EEE=0
insmod /lib/modules/4.19.0-16-amd64/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko EEE=0
Ahh ...
So now the unknown parameter is known?
Q: If it was unknown, wouldn't the -v have made modprobe print something to that effect?
man modprobe wrote:
-v, --verbose
      Print messages about what the program is doing. Usually modprobe only prints messages if something goes wrong.
It seems that the e1000e module has EEE enabled by default.
See https://access.redhat.com/documentation … t_Ethernet
Not only does it seem impossible to disable it via the usual methods: ethtool cannot query or access EEE settings because the e1000e does not support it.
No idea as to how to go about this, this EEE is probably the source of my bad shutdowns but if I can't reliably turn it off, it not possible to know.
ie: if I can't query the controller, how can I know?
A different driver, more up to date from Intel? IBM? RedHat?
A backport from Chimaera?
Any ideas would be welcome.
#2 2021-04-23 18:08:15
Re: Modules, modprobe(.d) and kernel command line
Check for the available module parameters:
ls /sys/module/e1000e/parameters
Official documentation here: https://www.kernel.org/doc/html/v4.19/n … e1000.html
No:
$ doas modprobe -v e1000e madeup_nonsense=1
insmod /lib/modules/5.11.16-zen1-1-zen/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko.xz madeup_nonsense=1
#3 2021-04-23 19:01:36
... available module parameters:
groucho@devuan:~$ ls /sys/module/e1000e/parameters
copybreak
groucho@devuan:~$ cat /sys/module/e1000e/parameters/copybreak
256
groucho@devuan:~$
Hmm ...
I think this is the e1000 driver but the 82566DM-2 controller uses the e1000e driver.
At least in my Devuan it loads the e1000e module.
groucho@devuan:~$ sudo ethtool -i eth0
driver: e1000e             <---- | x |
version: 3.2.6-k
firmware-version: 1.4-0
expansion-rom-version:
bus-info: 0000:00:19.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
groucho@devuan:~$
See https://downloadmirror.intel.com/15817/eng/readme.txt
No:
Ah ...
Thanks for the heads up, good to know.
No error for madeup_nonsense=1 then?
Thanks for your input.
#4 2021-04-23 19:08:27
Oh yes, sorry, my mistake. The 4.19 kernel documentation doesn't seem to have a section for the e1000e module, or at least not that I can find.
Here's the page for my 5.11 kernel: https://www.kernel.org/doc/html/v5.11/n … 1000e.html
You can also use the modinfo command.
The error message is printed to the kernel ring buffer rather than stdout or stderr:
 $ doas dmesg | grep e1000e
[13821.559641] e1000e: unknown parameter 'EEE' ignored
[13821.559729] e1000e: Intel(R) PRO/1000 Network Driver
[13821.559730] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[13922.922522] e1000e: unknown parameter 'madeup_nonsense' ignored
[13922.922575] e1000e: Intel(R) PRO/1000 Network Driver
[13922.922575] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
#5 2021-04-23 20:52:05
... sorry, my mistake.
Don't worry.  8^D
... 4.19 kernel documentation doesn't seem to have a section for the e1000e module ...
I found this:
https://www.kernel.org/doc/html/v5.2/ne … 1000e.html
The e1000 driver is no longer maintained by Intel and is integrated into the kernel.
Not the case with e1000e up to now. (?)
See: https://www.intel.com/content/www/us/en … ducts.html
Intel Support wrote:
Note
The e1000 driver is no longer maintained as a standalone component. Request support from the maintainer of your Linux* distribution.
and
The Linux* e1000e driver supports the Intel® PRO/1000 PCI-E (82563/6/7, 82571/2/3/4/7/8/9, or 82583) I217/I218/I219 based gigabit network adapters.
The drivers are only supported as a loadable module. We don't supply patches against the kernel source to allow for static linking of the drivers.
I don't think it will make any difference.
The thing is that there are many sources on the web explaining that e1000e.EEE=0 is what is used to turn off the %&$# EEE.
... error message is printed to the kernel ring buffer rather than stdout or stderr ...
I see ...
Edit:
Reading some more, I found a parameter called SmartPowerDownEnable:
Valid Range:    0,1
Default Value:    0 (disabled)
Allows the PHY to turn off in lower power states. The user can turn off this parameter in supported chipsets.
Just for the fun of it ...
[root@devuan groucho]# modprobe -v e1000e SmartPowerDownEnable=0
insmod /lib/modules/4.19.0-16-amd64/kernel/drivers/net/ethernet/intel/e1000e/e1000e.ko SmartPowerDownEnable=0
1972.926673] e1000e: eth0 NIC Link is Down
[ 2004.654613] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2004.654617] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2004.654790] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 2004.654793] e1000e 0000:00:19.0: PHY Smart Power Down Disabled
[ 2004.967316] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:14:4f:4a:a2:81
[ 2004.967321] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 2004.967388] e1000e 0000:00:19.0 eth0: MAC: 7, PHY: 6, PBA No: FFFFFF-0FF
[ 2007.811375] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[ 2007.811486] e1000e 0000:00:19.0 eth0: 10/100 speed: disabling TSO
groucho@devuan:~$
It works ...
But I'm not too enthusiastic about this one because I don't know exactly what it is or how close it is to EEE - or not.
In any case, default is 0 ie: disabled.
What do you think?
#6 2021-04-23 21:18:16
https://downloadmirror.intel.com/15817/eng/readme.txt wrote:
- EEE is not supported on all Intel(R) Ethernet Network devices or at all link speeds.
Check
# ethtool --show-eee eth0
#7 2021-04-23 21:51:49
Check
Yes, I'm aware than it is not supported in every NIC.
But if in this box I get this ...
groucho@devuan:~$ sudo ethtool --show-eee eth0
[sudo] password for groucho:
Cannot get EEE settings: Operation not supported
groucho@devuan:~$
... while at the same time, at every instance of a bad shutdown I get this:
Devuan GNU/Linux 3 devuan tty1
devuan login: [   286.719428] e1000e: eth0 NIC Link is Down
[287.219230] e1000e: EEE TX LPI TIMER: 00000000              <-------------- | x |
[287.223022] ACPI: Preparing to enter sleep state S5
[287.223551] reboot: Power down
... it is clear (to me) that this is a NIC that does support EEE.
At the same time, access to both the EEE status and settings via ethtool is disabled in the e1000e driver.
But I think I am (?) getting somewhere:
I now tried this:
[root@devuan groucho]# echo "options e1000e SmartPowerDownEnable=0" | sudo tee /etc/modprobe.d/e1000e.conf
groucho@devuan:~$
An update-initramfs -u -k all and a reboot later ...
[    2.147204] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.158309] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.169606] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.180672] e1000e 0000:00:19.0: PHY Smart Power Down Disabled           <-----  | x |
[    2.603166] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:14:4f:4a:a2:81
[    2.616729] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    2.637607] e1000e 0000:00:19.0 eth0: MAC: 7, PHY: 6, PBA No: FFFFFF-0FF
[   27.495860] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: None
[   27.507904] e1000e 0000:00:19.0 eth0: 10/100 speed: disabling TSO
groucho@devuan:~$
The tty1 on a plain sudo shutdown -h now instead the one I've been using sync && sudo ethtool -s eth0 wol d && sudo rmmod -s -v e1000e && sudo shutdown -h now shows no trace of the EEE TX LPI TIMER: 00000000 (have to check with a video grab)*.
If that is so, I'll start using the plain unedited shutdown script I  was using ie: sync && sudo shutdown -h now and wait to see if I get another bad shutdown.
Hopefully, I won't.  8^/
* Unfortunately, I can confirm that disabling SmartPowerDownEnable does not do much with/to EEE.
The tty1 output when shutting down with sync && sudo shutdown -h now shows the line e1000e: EEE TX LPI TIMER: 00000000, which unless I am mistaken, is telling me that EEE is still active.
Which is precisely what I want to avoid.  8^7
devuan login: [        ] e1000e: eth0 NIC Link is Down
[        ] EXT-fs (sdb1): re-mounted. Opts: (null)
[        ] kvm: exiting hardware virtualization
[        ] sd 7:0:3:0: [sdf] Syncronizing SCSI cache
[        ] sd 7:0:2:0: [sde] Syncronizing SCSI cache
[        ] sd 5:0:0:0: [sdb] Syncronizing SCSI cache
[        ] sd 5:0:0:0: [sdb] Stopping disk
[        ] sd 4:0:0:0: [sda] Syncronizing SCSI cache
[        ] sd 4:0:0:0: [sda] Stopping disk
[        ] e1000e: EEE TX LPI TIMER: 00000000    <--------- | x |
[        ] ACPI: Preparing to enter sleep state S5
[        ] reboot: Power down
