#1 2021-04-21 22:01:45
Rpisp
policy kit
It seems no matter how long I'm on Linux, the question of how to set up policy kit never gets easier.
Typically I just completely ignore it and use sudo for my needs (nopasswd in sudoers)
Is it advisable to go about things this way, or should I be setting up policy kit?
Is policy kit even necessary?
Sorry for my ignorance but I have to ask
Any help would be appreciated thank you
#2 2021-04-22 05:48:28
Re: policy kit
For what purpose do you want to set up policy kit?
If you want to use pkexec to launch GUI applications with superuser privileges (which is a bad idea) then you can create some authorisation rules for the programs. See the files provided by synaptic & gparted for examples of this.
No.
Black Lives Matter
#3 2021-04-22 18:51:51
Rpisp
Re: policy kit
While I have synaptic installed (for now, prefer apt) it did not create any policy pkla file?
In fact the folder is empty.
#4 2021-04-22 19:37:01
Re: policy kit
What folder? The file is at /usr/share/polkit-1/actions/com.ubuntu.pkexec.synaptic.policy
Black Lives Matter
