#1 2021-04-10 17:14:42
Nana (fsvk74)
Can I create my fork of Devuan Beowulf and Devuan Beofulf repos?
Hello! Can I create my fork of Devuan Beowulf and Devuan Beofulf repositories (main and contrib)?
#2 2021-04-19 22:35:04
Re: Can I create my fork of Devuan Beowulf and Devuan Beofulf repos?
Nana (fsvk74) wrote:
Hello! Can I create my fork of Devuan Beowulf and Devuan Beofulf repositories?
What's devuan beofulf? Is it a new derivative unknown for me? Either way, the answer is yes, you can create a fork of these repositories in the same way than devuan forks the repository of debian. Indeed, that's what amprolla is for. Take as an example gnuinos, whose repository is a fully amprolla setup taking devuan as a base.
(main and contrib)?
Yes, you can configure the sections in lib/config.py
