#1 2021-02-27 10:54:59
Johnnie390
I2C, Devuan and Raspberry PI 4B (8GB)
Hello all,
I am running the above in an Argonone M.2 case.
To control the built-in fan (temps/speed) for the case, there is software to do this (https://gitlab.com/DarkElvenAngel/argon … -0.3.x.zip).
This setup worked flawlessly on RPIOS 64-bit.
In /boot/config.txt, I have this entry   dtparam=i2c_arm=on, however I cannot speak to the I2C bus using e.g. i2cdetect -y 1 at all.
Example -
i2cdetect -y 1
Error: Could not open file `/dev/i2c-1' or `/dev/i2c/1': No such file or directory
root@magalas:~# i2cdetect -y 0
Error: Could not open file `/dev/i2c-0' or `/dev/i2c/0': No such file or directory
root@magalas:~#
As can be seen from the above screenshot, I am dead in the water before I start...
Anyone any ideas?
Regards,
J.
#2 2021-02-27 13:45:45
c0rnelius
Re: I2C, Devuan and Raspberry PI 4B (8GB)
sudo modprobe i2c-dev
cat /etc/modules If you see it already there, then uncomment it and upon reboot it should load every time. If not, just add it to the file. i2c-dev
#3 2021-02-27 14:43:12
Johnnie390
Had already uncommented the line in /etc/modules but I appreciate the assistance anyway.
Regards,
J.
#4 2021-02-27 15:02:48
c0rnelius
Alright, well I just installed some needed bits and it seems to be appearing for me.
uncomment:
dtparam=i2c_arm=on
dtparam=i2s=on
dtparam=spi=on
Install:
sudo apt install -y python3-dev python-smbus i2c-tools python3-pil python3-pip python3-setuptools python3-rpi.gpio
make sure the above modue is in /etc/modules and reboot.
Came right up:
ls /dev/i2c*
/dev/i2c-1
patrick@devuan:~$ sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
#5 2021-02-28 08:47:35
Johnnie390
Hallo all,
an entry in /etc/modules fixed same. Thanks.
J.
#6 2021-03-22 03:02:37
tuxd3v
hello Johnnie390,
Can you mark this thread as Solved? smile
Best Regards,
tux
