#1 2021-02-24 23:19:57
kby
[Solved] aa whines about being forcefully stopped on shutdown (OpenRC)
Hello,
I'm using Beowulf 3.1.0 as my daily driver. Everything's perfect — really, I even got audio to work (despite the kernel's horrible ALC295 support). There is one small issue though: Whenever I shutdown my computer, OpenRC reports the following as it's trying to stop AppArmor:
[warn] "stop" doesn't mean anything for this init script...
Forcefully unloading AppArmor profiles can make programs unstable...
[some more flavor text regarding AppArmor]
[ok] AppArmor profiles unloaded
The computer shuts down correctly. No errors on the next bootup. AppArmor outputs nothing to syslog. But on every shutdown, this happens.
Is this regular behaviour? I searched for bug reports on bugs.devuan.org and bugs.gentoo.org but there is nothing that mentions such behaviour.
Edit: I'm gonna try taking a picture of the warning and type down the exact message that's being shown
#2 2021-02-25 10:21:24
kby
Re: [Solved] aa whines about being forcefully stopped on shutdown (OpenRC)
Okay, I decided to uninstall OpenRC and just use plain sysvinit. That made the message disappear. I'll have to file a bug report for it, but beyond that, the problem is solved.
#3 2021-02-25 10:59:17
I use OpenRc but not AppArmor.
