#1 2021-01-28 14:47:51
ifdv44
nftables advice?
I'm still learning so be gentle.
It appears iptables is on the road to deprecation in the Debian repos and that nftables is the recommended replacement for maintaining a firewall on a machine. Is it safe to assume that Devuan will follow that (it appears to be the default install too) ?
I've never really poked at the firewalls on Linux until recently and a brief look at the syntax and documentation suggests the iptables rules are easier to read and that there is more documentation on them. However , while i can see the point in learning that, my time is limited and I'm looking for a clear guide to the syntax and some examples of nftables. I've been looking on the netfilter site and various other searches and I've gone a bit cross eyed. Any suggestions on where i might be advised to start learning from?. I dont want to lock myself out of the remote machine so will need SSH open at the minimum.
#2 2021-01-28 16:06:47
Re: nftables advice?
I think beowulf already defaults to the nftables backend as per https://www.debian.org/releases/stable/ … l#nftables
I do not agree with that at all. The nftables syntax looks *much* easier to understand IMO but I am pretty ignorant when it comes to firewalls so my opinion is probably moot.
I presume you've seen the nftables wiki? See also https://wiki.debian.org/nftables & https://wiki.archlinux.org/index.php/Nftables
The nftables package provides a few examples under /usr/share/doc/ and also has a sysvinit script that can be used in Devuan but it needs correcting:
https://dev1galaxy.org/viewtopic.php?id=2889
