Hello,
I'm a new user, was very curious about Devuan+runit, so I installed Beowulf, swtiched to runit and installed X plus Jwm.
When I tried startx as a user, however, X crashed.
I could startx as root, no problem, so I assume is a permission issue.
This is the xorg error log.
[ 891.752]
X.Org X Server 1.20.4
[ 891.756] Build Operating System: Linux 4.19.0-12-amd64 x86_64 Debian
[ 891.757] Current Operating System: Linux mac 4.19.0-13-amd64 #1 SMP Debian 4.19.160-2 (2020-11-28) x86_64
[ 891.758] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-13-amd64 root=UUID=00e362ae-f9be-4b77-9729-b7b8c62bf108 ro quiet
[ 891.761] Build Date: 01 December 2020 05:59:57PM
[ 891.762] xorg-server 2:1.20.4-1+deb10u2 (https://www.debian.org/support)
[ 891.762] Current version of pixman: 0.36.0
[ 891.764] Before reporting problems, check http://wiki.x.org
[ 891.764] Markers: (--) probed, (**) from config file, (==) default setting,
[ 891.767] (==) Log file: "/home/mac/.local/share/xorg/Xorg.0.log", Time: Sat Jan 16 12:04:28 2021
[ 891.779] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 891.796] (==) No Layout section. Using the first Screen section.
[ 891.796] (==) No screen section available. Using defaults.
[ 891.796] (**) |-->Screen "Default Screen Section" (0)
[ 891.796] (**) | |-->Monitor "<default monitor>"
[ 891.797] (==) No monitor specified for screen "Default Screen Section".
[ 891.797] (==) Automatically adding devices
[ 891.797] (==) Automatically enabling devices
[ 891.797] (==) Automatically adding GPU devices
[ 891.798] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 891.812] (WW) The directory "/usr/share/fonts/X11/misc" does not exist.
[ 891.813] Entry deleted from font path.
[ 891.813] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 891.813] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 891.813] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 891.813] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[ 891.813] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 891.813] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 891.813] (==) FontPath set to:
built-ins
[ 891.813] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 891.813] (II) The server relies on udev to provide the list of input devices.
[ 891.813] (II) Loader magic: 0x55889ac26e20
[ 891.813] (II) Module ABI versions:
[ 891.813] X.Org ANSI C Emulation: 0.4
[ 891.813] X.Org Video Driver: 24.0
[ 891.813] X.Org XInput driver : 24.1
[ 891.813] X.Org Server Extension : 10.0
[ 891.816] (++) using VT number 1
[ 891.817] (EE) systemd-logind: failed to get session: The name org.freedesktop.login1 was not provided by any .service files
[ 891.818] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 891.822] (--) PCI:*(0@0:2:0) 8086:0116:1028:04b0 rev 9, Mem @ 0xf6800000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 891.822] (II) LoadModule: "glx"
[ 891.824] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 891.922] (II) Module glx: vendor="X.Org Foundation"
[ 891.922] compiled for 1.20.4, module version = 1.0.0
[ 891.922] ABI class: X.Org Server Extension, version 10.0
[ 891.922] (==) Matched modesetting as autoconfigured driver 0
[ 891.922] (==) Matched fbdev as autoconfigured driver 1
[ 891.922] (==) Matched vesa as autoconfigured driver 2
[ 891.922] (==) Assigned the driver to the xf86ConfigLayout
[ 891.922] (II) LoadModule: "modesetting"
[ 891.923] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 891.934] (II) Module modesetting: vendor="X.Org Foundation"
[ 891.934] compiled for 1.20.4, module version = 1.20.4
[ 891.934] Module class: X.Org Video Driver
[ 891.934] ABI class: X.Org Video Driver, version 24.0
[ 891.934] (II) LoadModule: "fbdev"
[ 891.935] (WW) Warning, couldn't open module fbdev
[ 891.935] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 891.935] (II) LoadModule: "vesa"
[ 891.935] (WW) Warning, couldn't open module vesa
[ 891.935] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 891.935] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 891.952] (II) modeset(0): using drv /dev/dri/card0
[ 891.952] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 891.952] (II) modeset(0): Creating default Display subsection in Screen section
[ 891.952] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 891.952] (==) modeset(0): RGB weight 888
[ 891.952] (==) modeset(0): Default visual is TrueColor
[ 891.952] (II) Loading sub module "glamoregl"
[ 891.952] (II) LoadModule: "glamoregl"
[ 891.952] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 892.056] (II) Module glamoregl: vendor="X.Org Foundation"
[ 892.056] compiled for 1.20.4, module version = 1.0.1
[ 892.056] ABI class: X.Org ANSI C Emulation, version 0.4
[ 892.575] (II) modeset(0): glamor X acceleration enabled on Mesa DRI Intel(R) Sandybridge Mobile
[ 892.575] (II) modeset(0): glamor initialized
[ 892.576] (II) modeset(0): Output LVDS-1 has no monitor section
[ 892.577] (II) modeset(0): Output VGA-1 has no monitor section
[ 892.579] (II) modeset(0): Output HDMI-1 has no monitor section
[ 892.579] (II) modeset(0): Output DP-1 has no monitor section
[ 892.579] (II) modeset(0): EDID for output LVDS-1
[ 892.579] (II) modeset(0): Manufacturer: LGD Model: 2dc Serial#: 0
[ 892.579] (II) modeset(0): Year: 2010 Week: 0
[ 892.579] (II) modeset(0): EDID Version: 1.4
[ 892.579] (II) modeset(0): Digital Display Input
[ 892.579] (II) modeset(0): 6 bits per channel
[ 892.579] (II) modeset(0): Digital interface is undefined
[ 892.579] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 892.579] (II) modeset(0): Gamma: 2.20
[ 892.579] (II) modeset(0): No DPMS capabilities specified
[ 892.579] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 892.579] (II) modeset(0): First detailed timing is preferred mode
[ 892.579] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 892.579] (II) modeset(0): redX: 0.613 redY: 0.371 greenX: 0.350 greenY: 0.606
[ 892.579] (II) modeset(0): blueX: 0.152 blueY: 0.099 whiteX: 0.313 whiteY: 0.329
[ 892.579] (II) modeset(0): Manufacturer's mask: 0
[ 892.579] (II) modeset(0): Supported detailed timing:
[ 892.579] (II) modeset(0): clock: 76.0 MHz Image Size: 344 x 194 mm
[ 892.579] (II) modeset(0): h_active: 1366 h_sync: 1402 h_sync_end 1450 h_blank_end 1564 h_border: 0
[ 892.579] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 810 v_border: 0
[ 892.579] (II) modeset(0): clock: 51.0 MHz Image Size: 344 x 194 mm
[ 892.579] (II) modeset(0): v_active: 768 v_sync: 771 v_sync_end 776 v_blanking: 814 v_border: 0
[ 892.579] (II) modeset(0): 9HXXJ156WH4
[ 892.579] (II) modeset(0): Unknown vendor-specific block 0
[ 892.579] (II) modeset(0): EDID (in hex):
[ 892.579] (II) modeset(0): 00ffffffffffff0030e4dc0200000000
[ 892.579] (II) modeset(0): 00140104902213780a09159d5f599b27
[ 892.579] (II) modeset(0): 19505400000001010101010101010101
[ 892.579] (II) modeset(0): 010101010101b01d56c650002a302430
[ 892.579] (II) modeset(0): 350058c210000019ec1356c650002e30
[ 892.579] (II) modeset(0): 2430350058c210000019000000fe0039
[ 892.579] (II) modeset(0): 4858584a803135365748340a00000000
[ 892.579] (II) modeset(0): 00004131960100000001010a202000f7
[ 892.580] (II) modeset(0): Printing probed modes for output LVDS-1
[ 892.580] (II) modeset(0): Modeline "1366x768"x60.0 76.00 1366 1402 1450 1564 768 771 776 810 -hsync -vsync (48.6 kHz eP)
[ 892.580] (II) modeset(0): Modeline "1366x768"x40.1 51.00 1366 1402 1450 1564 768 771 776 814 -hsync -vsync (32.6 kHz e)
[ 892.580] (II) modeset(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 892.580] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 892.580] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 892.580] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 892.580] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 892.580] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 892.580] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 892.580] (II) modeset(0): Modeline "800x512"x120.3 51.56 800 800 828 832 512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 892.580] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "720x450"x119.8 53.25 720 760 836 952 450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)
[ 892.580] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 892.580] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 892.580] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "680x384"x119.6 42.38 680 716 784 888 384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "680x384"x119.9 36.00 680 704 720 760 384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "576x432"x120.1 40.81 576 608 668 760 432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 892.580] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 892.580] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 892.580] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 892.580] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 892.580] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 892.580] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 892.580] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 892.580] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 892.580] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 892.580] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 892.581] (II) modeset(0): EDID for output VGA-1
[ 892.583] (II) modeset(0): EDID for output HDMI-1
[ 892.583] (II) modeset(0): EDID for output DP-1
[ 892.583] (II) modeset(0): Output LVDS-1 connected
[ 892.583] (II) modeset(0): Output VGA-1 disconnected
[ 892.583] (II) modeset(0): Output HDMI-1 disconnected
[ 892.583] (II) modeset(0): Output DP-1 disconnected
[ 892.583] (II) modeset(0): Using exact sizes for initial modes
[ 892.583] (II) modeset(0): Output LVDS-1 using initial mode 1366x768 +0+0
[ 892.583] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 892.583] (==) modeset(0): DPI set to (96, 96)
[ 892.583] (II) Loading sub module "fb"
[ 892.583] (II) LoadModule: "fb"
[ 892.583] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 892.605] (II) Module fb: vendor="X.Org Foundation"
[ 892.606] compiled for 1.20.4, module version = 1.0.0
[ 892.606] ABI class: X.Org ANSI C Emulation, version 0.4
[ 892.606] (EE) modeset(0): drmSetMaster failed: Permission denied
[ 892.606] (EE)
Fatal server error:
[ 892.606] (EE) AddScreen/ScreenInit failed for driver 0
[ 892.606] (EE)
[ 892.606] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 892.606] (EE) Please also check the log file at "/home/mac/.local/share/xorg/Xorg.0.log" for additional information.
[ 892.606] (EE)
[ 892.627] (EE) Server terminated with error (1). Closing log file.Can anyone help me to solve the problem?
Don't know why but the issue solved itself on reboot. ![]()
