#1 2020-10-28 03:21:12
cretsiah
install guide doesnt match install screen
In the middle of installing
im at the stage of grub config and boot installtion
I have the the original debian looking text installer type screen (blue blackground, white writing, red square cursor)
how do I make the selection for \dev\sda  to install grub
didnt get the bios (32-bit suggested  screen show up)
#2 2020-10-28 06:40:55
larsH
Re: install guide doesnt match install screen
Hi
As far as I remember, you need to use the advanced install mode to get this. If you want grub to boot your machine directly it will in my experience always choose the right drive, especially if you are using uefi and secure boot (secure boot do not need to be enabled) but you then need a  esp partition.
Have a nice day
Lars H
