#1 2020-10-17 13:14:20
nEon
Zyxel NSA 320 armhl
Hej.
u-boot USB problem
starting USB...
USB0:   USB EHCI 1.00
scanning bus 0 for devices... EHCI timed out on TD - token=0x80008d80
EHCI timed out on TD - token=0x80008c80
 ERROR: NOT USB_CONFIG_DESC 8f
2 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
usb drive is connected.
#2 2020-10-17 22:45:14
tuxd3v
Re: Zyxel NSA 320 armhl
hello nEon,
What are the specs for that device?
cpu/Ram, ethernet, etc smile
Best Regards,
tux
#3 2020-10-19 09:29:41
nEon
#4 2020-10-19 15:25:23
tuxd3v
Is that cpu a armv5TE?
if it is, them its a armel device smile
Best Regards,
tux
#5 2020-10-19 19:25:40
nEon
Yes, I know. Mistake in topic, sorry. Im testing armel of course wink
Debian bodhi works fine, but I want to run Devuan smile
u-boot from bodhi show my usb drive. Kernel Devuan armel do not show usb drive and hdd on NSA 320.
#6 2020-10-20 03:35:48
tuxd3v
what kernel are you using in Devuan?
you can get the kernel config you have in bodhi..
modprobe configs
zcat /proc/config.gz
And then build a kernel for it smile
Best Regards,
tux
#7 2020-10-28 12:19:59
nEon
kernel devuan: https://pkgmaster.devuan.org/devuan/dis … 11-marvell
DIY, smile Roger that ;]
I only say, test on NSA320 and files form https://pkgmaster.devuan.org/devuan/dis … ler-armel/ .. failed wink
#8 2020-10-31 14:57:04
tuxd3v
Does you included in /boot the DTB file for NAS320?
you need the :
/lib/modules/linux-image-version
/boot/kernel
/boot/System.map
/boot/config
/usr/lib/linux-image.version/DTB_Maybe
Check your bodhi installation for this files and copy them over to a devuan rootfs.
I douldn't find in uboot mainline the zyxel Nas 320, to better to keep the uboot you have, and build only a kernel for it, or copy the bodhi one over to a devuan rootfs smile
Best Regards,
tux
