Hi guys,
I am here again, I have been trying Artix and Obarun, but I think that I feel more comfortable with Debian based distro.
I won't get in the details now but after installation I was able to create BTRFS raid, create my subvolumes, and run Devuan from them. But when I update GRUB it finds a second installation of Devuan when it is actually one. You can boot from SDA1 or SDB1 and you get same environment, but it is unwanted and probably a manifestation of a wrong step somewhere.
How can I get grub recognize properly the only Devuan the lies on the RAID striped mode over two disks?
May it depend by an that version of GRUB itself?
Anyway I found another method that create BTRFS RAID and SUBs during the installation time:
https://www.paritybit.ca/blog/debian-with-btrfs
Thanks!
Is this to be a challenge thread then? ![]()
Can we at least see the contents of /boot/grub/grub.cfg?
It is not a challenge...
But I'd like to have every steps working fine before to post something... ![]()
I re-did the installation and this time the issue doesn't happen, perhaps because I did all my steps clearly and in the right sequence, and now I have Devuan on a Btrfs RAID using subvolumes as partitions:
gnuser@devuan:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Devuan GNU/Linux 3 (beowulf)
Release: 3
Codename: beowulf
gnuser@devuan:~$ mount | grep btrfs
/dev/sdb1 on / type btrfs (rw,noatime,discard,space_cache,autodefrag,subvolid=268,subvol=/@)
/dev/sdb1 on /home type btrfs (rw,noatime,discard,space_cache,autodefrag,subvolid=270,subvol=/@home)
/dev/sda3 on /media/snapshots type btrfs (rw,relatime,space_cache,subvolid=5,subvol=/)
gnuser@devuan:~$ sudo btrfs fi df /
Data, RAID0: total=4.00GiB, used=3.64GiB
System, RAID1: total=32.00MiB, used=16.00KiB
Metadata, RAID1: total=256.00MiB, used=125.92MiB
GlobalReserve, single: total=16.00MiB, used=0.00B
gnuser@devuan:~$ sudo btrfs fi show
Label: 'btraid' uuid: cf6cf3c5-f308-46b8-b4e8-dea7ad870436
Total devices 2 FS bytes used 3.76GiB
devid 1 size 16.00GiB used 2.28GiB path /dev/sdb1
devid 2 size 16.00GiB used 2.28GiB path /dev/sdc
Label: 'snapshots' uuid: bcbe0d7f-14c9-4ad4-86c4-27362d64ef93
Total devices 1 FS bytes used 3.66GiB
devid 1 size 5.59GiB used 4.51GiB path /dev/sda3
gnuser@devuan:~$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 16G 0 disk
├─sda1 8:1 0 524M 0 part /boot/efi
├─sda2 8:2 0 525M 0 part /boot
├─sda3 8:3 0 5.6G 0 part /media/snapshots
└─sda4 8:4 0 9.4G 0 part
└─sda4_crypt 254:0 0 9.4G 0 crypt
├─vgcr0-swap 254:1 0 3.7G 0 lvm [SWAP]
└─vgcr0-enc 254:2 0 5.7G 0 lvm /mnt/private
sdb 8:16 0 16G 0 disk
└─sdb1 8:17 0 16G 0 part /home
sdc 8:32 0 16G 0 disk
sr0 11:0 1 1024M 0 rom I am almost ready to install Devuan on a real hardware!!! ![]()
By the way I think I solved the issue leaving the second disk in a partionless state, other thing is creating /boot outside of the btrfs filesystem; I did the same on my real hardware (WOW!!!
) and it worked.
Soon my recommendations or at least what I did... :-P
