#1 2019-12-26 16:40:39
Keyboard configuration issue
My Sun 7 keyboard went south, the second one this year.
Nice but not so trusty after all.
So I pulled an old Lenovo backup from the closet: KU-0225 / P/N: 41A5312
It's a standard 105-key Latin American layout keyboard.
But something is not right and I cannot figure out what it is.
I have set the layout with dpkg-reconfigure keyboard-configuration and my /etc/default/keyboard file reads accordingly.
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="latam"
XKBVARIANT="nodeadkeys"
XKBOPTIONS="lv3:ralt_switch,compose:menu,terminate:ctrl_alt_bksp"
BACKSPACE="guess"
It seems that the keyboard configuration setting is being ignored and the keyboard is working as if it were a Spanish layout (like if it had a ç / Ç at the end of the third row).
eg: The key that should give me an accent ` or two types of brackets { or } and [ or ] gives me a ç or a Ç.
Rather annoying.
Any idea what might be happening here?
Thanks in advance,
#2 2019-12-27 12:49:21
Re: Keyboard configuration issue
Is this with Xfce? Perhaps the desktop is overriding your configuration.
#3 2019-12-27 13:00:36
... Xfce?
... desktop is overriding your configuration.
Thought that could be the case, so tried Applications -> Settings -> Keyboard -> Layout, un-checked Use system defaults and chose Generic 105-key PC (intl.) with Spanish (Latin American) layout and Spanish (Latin American, no dead keys) variant.
But no, no cigar.
Thanks for your input.
#4 2019-12-27 15:58:10
HevyDevy
maybe try to configure the keyboard with setxbmap ?
http://xahlee.info/linux/linux_xkb_tutorial.html
#5 2019-12-27 21:13:46
HevyDevy wrote:
... configure the keyboard with setxbmap ?
Hmm ...
What I want is to be able to configure it via the desktop settings like it should be done.
ie: Applications -> Settings -> Keyboard -> Layout
rant
This is the type of thing that gets on Linux users' nerves: a straightforward configuration glitch in something that (at this stage in Linux time) should not be happening.
After all, how long has Xfce been a desktop option?
/rant
So if it wants to use the system defaults (the previous setting), I guess I'll have to try setting the system defaults to what I want.
Any other ideas?
Cheers,
#6 2019-12-28 11:21:07
rant
/rant
The issue I am having with the keyboard settings in Xfce seems to be related to a well known bug from back in 2010.
Nine (9) years ago and counting ....
https://askubuntu.com/questions/66096/h … er-reboots
Like someone else posted on that thread:
... u understand now why linux share in desktops is ~1%
A simple stupid language switcher applet is bugged for years...
I'll see if I can make one of the workarounds (evidently considered a permanent fix by the developers) work for me.
Cheers,
#7 2019-12-28 12:20:27
HevyDevy
have you tried setxbmap as a workaround to see if it fixes the issue? Not with the plugin, just your keyboard layout.
#8 2019-12-28 12:52:49
HevyDevy wrote:
... tried setxbmap as a workaround ...
Yes, it works.
I can set the layout with setxkbmap.
But it does not survive a reboot.
Where can I set it to make it permanent?
Cheers,
#9 2019-12-28 13:01:39
HevyDevy
you need to put the command in your autostart file, for xfce i think it is .xprofile if you are not using a login manager. I dont use desktop managers or desktop environments so im just guessing here.
#10 2019-12-28 13:27:28
HevyDevy wrote:
... put the command in your autostart file ...
Done.
Applications -> Settings -> Session and Startup -> Application Autostart -> Add
Name: keyboardmap (or whatever)
Description: sets kb layout (or whatever)
setxkbmap latam
Thank you very much for your help.
That this issue is still a problem after so many years is not a good omen, not for Xfce and certainly not for the Linux ecosystem.
Cheers,
#11 2019-12-28 13:52:19
HevyDevy
xfce does many things well but fails in some areas that have been accomplished by simpler means, i used it awhile ago but it never lasted long on my disks. Xfce has the multi monitor display working well i believe, or so i have read.
#12 2019-12-28 14:37:23
HevyDevy wrote:
... does many things well ...
Like all the other mainsream desktops out there these days.
HevyDevy wrote:
... fails in some areas ...
I'd say far too many, but as I suffer its shortcomings I cannot be objective enough.
HevyDevy wrote:
... has the multi monitor display working well ...
Just like Mate or Cinnamon or Gnome (which I have not tried).
But that is probably because X is working reasonably well and when it does not, some *.orx/layouts get it fixed quick enough.
For example: I've been waiting years for Xfce to be able to line up/organise/keep the desktop icons where I bloody put them.
It's the one thing I miss from XP.
I have been seriously thinking about getting rid of Xfce once and for all but never get around to doing so, probably for fear of breaking my Devuan ASCI .
Cheers,
#13 2019-12-28 14:57:48
HevyDevy
hey altoid, if it is working with a few failures on some trivial plugins then i would keep it around if you are familiar with it. linux/unix does not do everything i would like it to, but it is a lot better than some alternatives out there, i also come from an XP background, started out in win98 and had no idea how to use it, wish i had of been exposed to unix and or linux back then in the mid 90's but we were mostly playing around with nintendos and playstations, the personal computer was a really expensive item i was only able to purchase in 1998 when i came into some money. Pretty much boom time back around the late 90's for computing, the focus was on multimedia.
fast forward... I like to be able to configure my systems minimally where i know what programs do what instead of having a suite handle all the tasks. For example i run openbox and dwm as window managers for X. So i know how to configure window management to work with the X display software. It has its limits but to me those limits are worthwhile.
