#1 2019-10-18 17:28:57
boycottsystemd
ASCII: does unattended-upgrade give latest kernel security update ?
$ uname -a
Linux devuan 4.9.0-9-686-pae #1 SMP Debian 4.9.168-1+deb9u5 (2019-08-11) i686 GNU/Linux
and
# unattended-upgrade
gives nothing
but
For the oldstable distribution (stretch), these problems have been fixed in version 4.9.189-3+deb9u1.
https://www.debian.org/security/2019/dsa-4531
Does unattended-upgrade give latest kernel security update ?
#2 2019-10-18 19:44:01
Re: ASCII: does unattended-upgrade give latest kernel security update ?
Do you have the kernel metapackage installed?
apt policy linux-image-686-pae
"Il semble que la perfection soit atteinte non quand il n'y a plus rien à ajouter, mais quand il n'y a plus rien à retrancher." — Antoine de Saint-Exupéry
#3 2019-10-20 18:33:28
boycottsystemd
thank you, I'll check it when possible.
#4 2019-11-06 08:17:59
boycottsystemd
$ apt policy linux-image-686-pae
linux-image-686-pae:
  Installed: 4.9+80+deb9u9
  Candidate: 4.9+80+deb9u9
  Version table:
 *** 4.9+80+deb9u9 500
        500 http://pkgmaster.devuan.org/merged ascii/main i386 Packages
        100 /var/lib/dpkg/status
     4.9+80+deb9u6 500
        500 http://pkgmaster.devuan.org/merged ascii-security/main i386 Packages
I wasn't aware this was needed. Are there any other packages needed for unattended-upgrade to work corectly ?
#5 2019-11-07 17:31:18
No, but you do need to configure it: https://wiki.debian.org/UnattendedUpgrades
tl;dr:
# dpkg-reconfigure -plow unattended-upgrades
#6 2019-11-15 08:14:14
boycottsystemd
tl;dr:
Thank you. Is it necessary when unattended-upgrade is called manually ?
#7 2019-11-16 19:40:27
Why would you do that? That would be an attended unattended upgrade then? hmm
#8 2019-11-17 09:23:05
boycottsystemd
Because I need security updates only.
Second, it is good to check it's functionality sometimes by manual calling.
#9 2019-11-17 10:29:45
That's the default setting, see the comments in /etc/apt/apt.conf.d/50unattended-upgrades
Yes, I suppose.
#10 2019-11-18 07:21:08
boycottsystemd
Yes, I suppose.
Well, thank you.
If we can return to original question, it could be e.g. such:
Does (manually called) unattended-upgrade give latest kernel security update ?
