#1 2019-09-10 15:34:39
Raul
No headphones. Upgrade Ascii > Beowulf
Well, I just thought I had resolved a problem getting audacity 2.2. on my computer by upgrading from ascii to beowulf.
But I find that on beowulf the sockets for the external microphone/headphones do not work. The audio system does, I can hear the external loudspeaker.  If I plug the headphones, all sounds disappear.
I am using an old machine, Dell Latitude D630. Still, all that worked very well with Ascii (and Stretch).
Thanks for some suggestions.
Raúl
#2 2019-09-10 16:49:36
bgstack15
Re: No headphones. Upgrade Ascii > Beowulf
Sometimes in GNU/Linux, whenever I unplug/plug in something to the audio I/O ports, I have to adjust the volume in the OS before any audio is then sent. I also own a D630, so I can help test stuff as needed. I run only beowulf/ceres, so is that going to be close enough for you?
