Hi.
I built a working ASCII image for Raspberry 2 using arm-sdk.
Nevertheless, I'm unable to configure the keyboard no matter what:
dpkg-reconfigure keyboard-configuration does not work because keyboard-configuration is not installed (in amd64 image it is present).
Installing keyboard-configuration did not solve the problem unfortunately - it silently fails with no error whatsoever, also without displaying anything, and with return code 0. Installing the whole suite of packages it might depend on (console-setup console-setup-linux kbd keyboard-configuration xkb-data) also didn't fix the problem.
Any ideas please?
...bump?
