#1 2019-05-18 11:10:32
eeepc-acpi-scripts in ASCII
I need to install the eeepc-acpi-scripts package in ASCII but it is not listed by apt:
groucho@devuan:~$ sudo apt-get install eeepc-acpi-scripts
[sudo] password for groucho:
Building dependency tree
E: Unable to locate package eeepc-acpi-scripts
groucho@devuan:~$
Notwithstanding, according to https://pkginfo.devuan.org/cgi-bin/d1pk … elease=any it is available for Devuan:
2 results for "eeepc-acpi-scripts" in any (in 19.878343ms)
    [ceres] eeepc-acpi-scripts-1.1.13
    [jessie] eeepc-acpi-scripts-1.1.12
What would be the correct way of installing this package?
Add one of these two repositories to sources.list?
If so, which would be the appropriate one?
#2 2019-05-18 16:04:22
Panopticon
Re: eeepc-acpi-scripts in ASCII
You would have to upgrade to unstable/ceres for that i think, or do some sort of apt repository pinning magic.
I would have a try at installing from upstream source first maybe?
https://github.com/nbigaouette/acpi-eeepc-generic
#3 2019-05-18 16:38:03
You could try adding the jessie repositories then update the APT database and install the package, I've just tried a simulation on my Debian buster system and it seems to work.
Remember to remove the jessie source and update again afterwards though.
#4 2019-05-18 16:52:35
Panopticon wrote:
... upgrade to unstable/ceres ...
... some sort of apt repository pinning magic.
No, I've tried too much magic recently.
It's a backport or I won't try. =- ^
Panopticon wrote:
... try at installing from upstream source first maybe?
Thanks, I'll have a look at that.
The reason for Devuan repositories having packages for jessie eeepc-acpi-scripts-1.1.12 and ceres eeepc-acpi-scripts-1.1.13 but not for ASCII is probably because there's no  package in the Debian repository for stretch either:
https://packages.debian.org/search?keyw … pi-scripts
Package eeepc-acpi-scripts
    jessie (oldstable) (utils): Scripts to support suspend and hotkeys on the Asus Eee PC laptop
    1.1.12: all
    sid (unstable) (utils): Scripts to support suspend and hotkeys on the Asus Eee PC laptop
    1.1.13: all
Maybe it is something that's happened somewhere in ASCII (and obviously affects how the package works) that was not in jessie and won't be in ceres?
Thanks for your input.
