#1 2019-05-16 13:06:29
sgage
MATE volume control issue (beowulf)
Running MATE over beowulf, and have been having the following issue for quite some time:
It involves using the mouse scroll wheel over the volume indicator to adjust volume. It will scroll down (lowering volume), but will only scroll up a few percent before it hits a ceiling (usually 30%). You can scroll down all you want, to zero, but then it will only scroll up to 7% before pegging. So you essentially ratchet down. Everything works as expected in buster, FWIW.
Any ideas as to what could be causing this?
TIA
#2 2019-05-16 17:22:27
xinomilo
Unknown
Re: MATE volume control issue (beowulf)
never had such an issue with MATE - beowulf.
using experimental MATE right now, so can't confirm this.
maybe send a bug report with details, ~/.xsession-errors perhaps and whatever related in system logs?
also did you try using alsamixer from console to see if that's a pulseaudio-mate thing, or something else?
