Pages: 1
New installation of Jessie 32 bit is booting significantly faster than ASCII 64 bit (migrated from Debian). Is the difference caused by state of "new" and "old" installation ?
Check daemons running during init-rc. For example, Debian Wheezy 64 bit boot time (from kernel to login) on HDD after clean install was about 7 seconds with sysvinit+sysvrc.
thank you, I will check it.
Use bootchart to analyse boot performance.
EDIT: typo.
Pages: 1
