When opening gnome-software from a terminal and then clicking on Software Repositories (inside gnome-software) I get these errors, rendering gnome-software useless:
(software-properties-gtk:5094): dbind-WARNING **: 22:36:20.656: Couldn't register with accessibility bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
ERROR:root:Cannot import UbuntuDrivers: No module named 'UbuntuDrivers'
File "/usr/bin/software-properties-gtk", line 101, in <module>
app = SoftwarePropertiesGtk(datadir=options.data_dir, options=options, file=file)
File "/usr/lib/python3/dist-packages/softwareproperties/gtk/SoftwarePropertiesGtk.py", line 109, in __init__
SoftwareProperties.__init__(self, options=options, datadir=datadir)
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 109, in __init__
self.reload_sourceslist()
File "/usr/lib/python3/dist-packages/softwareproperties/SoftwareProperties.py", line 599, in reload_sourceslist
self.distro.get_sources(self.sourceslist)
File "/usr/lib/python3/dist-packages/aptsources/distro.py", line 93, in get_sources
(self.id, self.codename))
aptsources.distro.NoDistroTemplateException: Error: could not find a distribution template for Devuan/n/aI should probably mention that I'm still experiencing this issue https://dev1galaxy.org/viewtopic.php?id=2803 so it might cause this issue? I don't know, in any case, when that issue will get solved, I'll make sure to re-test this again.
Thanks.
