#1 2019-04-09 16:50:11
bbatten
[SOLVED] how to go downrev with opera
Well, the latest version of opera (60.0.3255.27) is - in my view - totally screwed up.
Can I revert to Devuan's previous version? If so, how?
Thanks,
#2 2019-04-09 17:30:19
nixer
Re: [SOLVED] how to go downrev with opera
I don't think that there is/was a "Devuan" version, because it is not supported in debian.
How did you install it?  Was it with the repo mentioned here: https://wiki.debian.org/Opera ?
I would suggest to uninstall the "broken" version that you have and download and install the older version.  I am currently booted into ceres and I do not see it in the official repositories.
#3 2019-04-09 20:56:19
bbatten
You're right. The file is
/etc/apt/sources.list.d/opera-stable.list
which I think was provided by the original manual opera installation. That file contains
I can't find an "old-stable" on opera's download site, which is what I guess I'm really looking for.
Thanks,
#4 2019-04-10 06:30:26
ToxicExMachina
You can also upgrade Opera to Otter Browser: https://otter-browser.org/
It's original-Opera-style browser.
wink
#5 2019-04-10 16:12:50
bbatten
FWIW, I found a link to my previous version here.
I downloaded it with wget and installed with dpkg -i. Works a treat.
