#1 2019-03-14 10:25:05
RIA77
Synaptic touchpad issues
Dear memebers of the forum,
I have been using Devuan 2.0 XFCE.
I have the following problem - there is no any option "tap to click" in settings. In order to click, I have to left click with touchpad.
Can anyone help ?
Thank you.
#2 2019-03-14 12:38:03
Panopticon
Re: Synaptic touchpad issues
If your laptop supports this go ahead and install xserver-xorg-input-synaptics.
then create a .xsession text file in your home folder if it is not already there and enter below into it.
@synclient TapButton1=1 TapButton2=3 TapButton3=2 &
startxfce4
then reboot.
Edit sorry this may or may not work, depends if you use the default xsession when logging in via the login manager. So just choose default xsession when logging in.
#3 2019-03-15 07:45:55
RIA77
I can't made .txt file, I tried, but when I edit that file, it became without .txt.
#4 2019-03-15 11:19:09
Panopticon
I didnt mean make the file format .txt i just meant the file should contain the text i put in code block.
#5 2019-03-15 12:09:07
RIA77
Thank you it works.
