#1 2017-08-04 03:31:31
fungus
apt failure /usr/bin/apt-listchanges: not found [SOLVED]
I am on Ceres/AMD64
/bin/sh: 1: /usr/bin/apt-listchanges: not found
E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1)
E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10
Even trying to install apt-listchanges gives the same error as I get in pretty much anything
I try to install.
Something I recently try to install involved lsb and remember reading that this does not constitute Devuan's LSB compliance.
Can it be related?
#2 2017-08-04 05:36:07
fungus
Re: apt failure /usr/bin/apt-listchanges: not found [SOLVED]
Something had gotten twisted in /etc/apt/apt.conf.d and although I couldn't pinpoint it, I moved the whole thing to a temp folder and then I changed sources back to ascii (from ceres).  At some point after updating I installed apt-listchanges for ascii.  Then I switched back to ceres and
upgraded, there seemed to be 6 files to be upgraded which didn't come up 2-3 hours ago.  Seems like it is self-fixed again.
