#1 2026-05-10 00:55:22
deepforest
[SOLVED] HP, Inc ScanJet G3010 could not open USB device Access denied
Devuan Excalibur... linux mess - sado-mazo again((
Scanner not working
freeartist-devuan@devuan:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 214b:7000 Huasheng Electronics 4-port hub [Maxxter ACT-HUB2-4P, HS8836, iSoul ultra-slim]
Bus 001 Device 004: ID 03f0:4205 HP, Inc ScanJet G3010
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 1038:1706 SteelSeries ApS SteelSeries Rival 95 Gaming Mouse
freeartist-devuan@devuan:~$ sane-find-scanner -q
could not open USB device 0x03f0/0x4205 at 001:004: Access denied (insufficient permissions)
could not open USB device 0x214b/0x7000 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0002 at 001:001: Access denied (insufficient permissions)
could not open USB device 0x1038/0x1706 at 005:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 005:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 004:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 003:001: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 002:001: Access denied (insufficient permissions)
freeartist-devuan@devuan:~$ groups
freeartist-devuan lp cdrom floppy audio dip video plugdev users netdev scanner lpadmin
smile
pyzNi 3.14zDa! smile
#2 2026-05-10 01:53:11
rbit
Re: [SOLVED] HP, Inc ScanJet G3010 could not open USB device Access denied
Strange indeed.  I have the same scanner.  On daedalus, it works fine.
$ lsusb
Bus 005 Device 013: ID 03f0:4205 HP, Inc ScanJet G3010
found possible USB scanner (vendor=0x03f0 [hewlett packard], product=0x4205 [hp scanjet]) at libusb:005:013
But, on excalibur I got the same result as you.  So, I went through /etc/group and added my user to EVERY group there.  Nothing worked...
fcc@fccvm:~$ sane-find-scanner -q
could not open USB device 0x03f0/0x4205 at 001:003: Access denied (insufficient permissions)
could not open USB device 0x80ee/0x0021 at 001:002: Access denied (insufficient permissions)
could not open USB device 0x1d6b/0x0001 at 001:001: Access denied (insufficient permissions)
fcc@fccvm:~$ groups
fcc daemon bin sys adm tty disk lp mail news uucp man proxy kmem dialout fax voice cdrom floppy tape sudo audio dip www-data backup operator list irc src shadow utmp video sasl plugdev staff games users netdev input kvm render Debian-exim ntpd messagebus _ssh plocate scanner rtkit lpadmin bluetooth ssl-cert uuidd avahi pulse pulse-access saned colord polkitd crontab nogroup
... until I added the group "root".   then it worked.
could not fetch string descriptor: Operation timed out
found possible USB scanner (vendor=0x03f0, product=0x4205) at libusb:001:003
fcc@fccvm:~$ groups
fcc root daemon bin sys adm tty disk lp mail news uucp man proxy kmem dialout fax voice cdrom floppy tape sudo audio dip www-data backup operator list irc src shadow utmp video sasl plugdev staff games users netdev input kvm render Debian-exim ntpd messagebus _ssh plocate scanner rtkit lpadmin bluetooth ssl-cert uuidd avahi pulse pulse-access saned colord polkitd crontab nogroup
A little more info.
Daedalus (working)
$ getfacl /dev/bus/usb/005/013
getfacl: Removing leading '/' from absolute path names
# file: dev/bus/usb/005/013
# owner: root
# group: root
user::rw-
user:tempo:rw-
group::rw-
group:scanner:rw-
mask::rw-
other::r--
Excalibur (not working)
 $ getfacl /dev/bus/usb/001/003
# file: dev/bus/usb/001/003
# owner: root
# group: root
user::rw-
group::rw-
other::r--
#3 2026-05-10 02:09:59
deepforest
Thank you man for help, i will try yours solution
but i found yet one fix for that
add this lines
ATTRS{idVendor}=="03f0", ATTRS{idProduct}=="4205", MODE="0666", GROUP="scanner", ENV{libsane_matched}="yes"
SYSFS{idVendor}=="03f0", SYSFS{idProduct}=="4205", MODE="664", GROUP="scanner"
to
/etc/udev/rules.d/40-libsane.rules
and reboot
smile
#4 2026-05-10 02:13:48
deepforest
What HPLIP driver are you using?
Under Linux i have stage wide blue tint lines at scanned images but at Windows VueScan all looks good.
smile
#5 2026-05-10 02:13:53
rbit
OK, you found the solution smile
On daedalus, I just use xsane
Not sure what driver it uses.
it reports: Loaded backend: hp3900:libusb:005
#6 2026-05-10 02:23:54
deepforest
Do you have any ideas where here can be issue with wrong weird blue tint wide stripes?
smile
#7 2026-05-10 02:45:12
deepforest
"blue tint" issue seem bug of sane
similar issue here
https://gitlab.com/sane-project/backend … _items/203
smile
#8 2026-07-09 21:12:43
deepforest
its not bug:) its was dust at inside mirrors, after gentle cleaning no more any color issues:)
smile
#9 2026-07-14 22:21:17
Catnip
I know this is for a different scanner but I wanted to add to this list.   Cannon LiDE 110, Devuan 6
$ lsusb
Bus 001 Device 006: ID 04a9:1909 Canon, Inc. CanoScan LiDE 110
sudo adduser [yourname] saned
sudo adduser [yourname] scanner
nano /etc/udev/rules.d/65-libsane.rules
# for Cannon LiDE110 add the following in 65-libsane.rules
ATTRS{idVendor}=="04a9", ATTRS{idProduct}=="1909", MODE="0664", GROUP="scanner", ENV{libsane_matched}="yes"
then reboot your system.   The scanner should be working with sane-utils and i prefer to use simple-scan.
for what it is worth this scanner is working good, no color issues.
