#1 2026-04-28 09:53:05
gfp
[SOLVED] GENUEN starting GUI
in starting Genuen I got only the terminal without GUI
after entering:
startx
it opened the last Cinnamon session.
What command would be to start a wayland session?
#2 2026-04-28 13:47:47
Re: [SOLVED] GENUEN starting GUI
Maybe you have various display managers installed (e.g. lightdm and sddm). You should define the one you want in /etc/X11/default-display-manager to end up at the login dm.
#3 2026-04-29 13:50:44
gfp
I have got only one installed.
/usr/sbin/lightdm
#4 2026-04-29 14:21:26
gfp
again starting Genuen stopped at the terminal.
I press ENTER
then I have to enter my user name with password
after that I have to
startx
in order to start the GUI
where again I have to enter my user name and password.
in the auth.log file:
may be here is something visible
2026-04-29T16:02:43.397405+02:00 Tuxedo elogind[5015]: New seat seat0.
2026-04-29T16:02:43.430647+02:00 Tuxedo polkitd[5447]: Loading rules from directory /etc/polkit-1/rules.d
2026-04-29T16:02:43.431456+02:00 Tuxedo polkitd[5447]: Loading rules from directory /run/polkit-1/rules.d
2026-04-29T16:02:43.431673+02:00 Tuxedo polkitd[5447]: Error opening rules directory: Error opening directory “/run/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
2026-04-29T16:02:43.431827+02:00 Tuxedo polkitd[5447]: Loading rules from directory /usr/local/share/polkit-1/rules.d
2026-04-29T16:02:43.431913+02:00 Tuxedo polkitd[5447]: Error opening rules directory: Error opening directory “/usr/local/share/polkit-1/rules.d”: No such file or directory (g-file-error-quark, 4)
2026-04-29T16:02:43.432135+02:00 Tuxedo polkitd[5447]: Loading rules from directory /usr/share/polkit-1/rules.d
#5 2026-04-29 14:22:50
gfp
should I install gdm ?
#6 2026-04-29 18:38:45
Polkitd looks for authorisation rules in several directories, but cannot find them. Polkit simply reports that these optional directories are not present. But this is not a serious issue as long as it manages to load the basic rules.
#7 2026-04-30 10:49:56
gfp
How can I copy or save the messages which come up when starting Genuen?
Where are those messages saved?
in /var/log/ there are many log files.
Which one shows exactly that, which comes up when booting Genuen?
I checked several, but didn't find exactly those which I was looking for.
#8 2026-04-30 18:54:18
in /var/log/boot, but you need to install bootlogd
#9 2026-04-30 23:28:35
gfp
bootlogd  is already installed
but the file /var/log/boot  is empty.
It does not record anything until now.
there are several messages that xorg can't start, but I can't recall them by heart. That´s why I want to get those messages.
there are messages in /var/log/syslog:
2026-05-01T01:07:34.694355+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.687:208): apparmor="ALLOWED" operation="open" profile="Xorg" name="/etc/udev/udev.conf" pid=7419 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
2026-05-01T01:07:34.694406+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.687:209): apparmor="ALLOWED" operation="open" profile="Xorg" name="/proc/7419/mounts" pid=7419 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
2026-05-01T01:07:34.698272+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.691:210): apparmor="ALLOWED" operation="mkdir" profile="Xorg" name="/dev/metadata/udev/events/serial/libudev-7419-0/" pid=7419 comm="Xorg" requested_mask="c" denied_mask="c" fsuid=1000 ouid=1000
2026-05-01T01:07:34.698307+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.691:211): apparmor="ALLOWED" operation="open" profile="Xorg" name="/proc/7419/mounts" pid=7419 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=1000
2026-05-01T01:07:34.710359+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.703:212): apparmor="ALLOWED" operation="open" profile="Xorg" name="/run/systemd/sessions/2" pid=7419 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
2026-05-01T01:07:34.710398+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.703:213): apparmor="ALLOWED" operation="open" profile="Xorg" name="/run/systemd/sessions/2" pid=7419 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
2026-05-01T01:07:34.822306+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.815:214): apparmor="ALLOWED" operation="open" profile="Xorg" name="/dev/metadata/udev/data/c226:0" pid=7419 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
2026-05-01T01:07:34.862283+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.855:215): apparmor="ALLOWED" operation="open" profile="Xorg" name="/etc/udev/udev.conf" pid=7420 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
2026-05-01T01:07:34.862328+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.855:216): apparmor="ALLOWED" operation="open" profile="Xorg" name="/proc/7420/mounts" pid=7420 comm="Xorg" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
2026-05-01T01:07:34.862337+02:00 Tuxedo kernel: audit: type=1400 audit(1777590454.855:217): apparmor="ALLOWED" operation="mkdir" profile="Xorg" name="/dev/metadata/udev/events/serial/libudev-7420-0/" pid=7420 comm="Xorg" requested_mask="c" denied_mask="c" fsuid=0 ouid=0
#10 2026-05-02 09:39:58
prospero
You may want to have a look in /var/log/Xorg.0.log.
#11 2026-05-02 14:19:50
gfp
starting Genuen
starting network connection manager: Network manager
ok: run: dbus: (pid 4990) 1s
those are the last messages
then waiting
still one message about acpi error
and nothing more
It can't start Xorg.
the first messages in the file: /var/olg/Xorg.0.log:
[   124.745]
X.Org X Server 1.21.1.16
[   124.745] Current Operating System: Linux Tuxedo 6.1.0-27-amd64 #1 SMP PREEMPT_DYNAMIC Gnuinos 6.1.115-1 (2024-11-01) x86_64
[   124.745] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-27-amd64 root=UUID=8921d97a-ed7c-4ea7-b703-25e7d8c31647 ro quiet
[   124.745] xorg-server 2:21.1.16-1.3+deb13u1devuan1 (https://www.devuan.org/os/community)
[   124.745] Current version of pixman: 0.44.0
[   124.745]     Before reporting problems, check http://wiki.x.org
[   124.745] Markers: (--) probed, (**) from config file, (==) default setting,
[   124.746] (==) Log file: "/var/log/Xorg.1.log", Time: Sat May  2 16:04:33 2026
[   124.746] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   124.747] (==) No Layout section.  Using the first Screen section.
[   124.747] (==) No screen section available. Using defaults.
How can I may be reinstall XOrg ...  to get the GUI?
#12 2026-05-03 00:25:32
prospero
This does not show any error.
You could run cat /var/log/Xorg.0.log | grep "(EE)" and see what that digs up.
#13 2026-05-03 04:24:02
There's also something Hyperbola GNU/Linux-libre devs found called sx
It does what startx does but is even more minimal and I have used it, no issues once its all set up. Then you just copy paste a backup in case when you reinstall your os, etc...
#14 2026-05-04 15:30:41
gfp
running
gives the message:
the interesting thing is that after installing Genuen approx. 5 times opening it everything worked well.
after that XOrg server does not work anymore.
I tried 3 times to install Hperbola, but it failed,
then I gave up because my knowledge is too little.
I also now too little to follow zappers proposal.
#15 2026-05-04 18:41:07
prospero
Maybe it does, but on a different tty. If you press Ctrl+Alt+F7 instead of entering startx, what are you getting?
#16 2026-05-05 09:37:04
gfp
Crtl+Alt+F7 gives the same as F1, I have to enter my user ID and password.
I tried to to take a photo  but I don't know how to get it into this message.
there are problems with
[libseat/backend/seat.c:64] could not connect to socket /run/satd.sock: No such fule or directory....
#17 2026-05-05 10:06:58
It obviously cannot be repeated enough times, but Xorg and Xlibre have off-loaded the opeings of device nodes and files to an external mediator, which (presently) is one of 1)  seatd via socket, 2) elogind via dbus or 3) seatd as subproces. The fallback, option 3, requires that the X server is run by a user with due read-write access to all required device nodes and files, whereas options 1 and 2 only requires read-write access to the communication socket. Though options 1 and 2 require their surrounding services.
Choose your use case.
#18 2026-05-05 12:16:18
gfp
thanks for clearification
I did not know that.
I don´t mind which option to choose, it should just work.
How can I choose this or that, what do I have to do?
#19 2026-05-05 17:41:55
prospero
I would suggest installing afresh from the latest genuen 6 excalibur iso:
https://www.genuen.org/mirror/excalibur
Here it is booting fine and fast into a graphical session. I suppose the external mediation is provided by case 2 above (dbus and elogind), but did not have time to investigate further.
